PS3 controller.......not working????
Old Apr 18, 2008 | 04:54 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
Default PS3 controller.......not working????
My PS3 controller has misteriously stopped working without the cable?? It will not play without the lead in. If i take the charging lead out and press the ps3 button it flashes all 4 lights as usual but doesnt assign itself as the 1st controller. Is the controller knackered or am i doing something daft?????
Old Apr 18, 2008 | 04:58 PM
Stoo's Avatar
Stoo
When did this start and what were you playing?
As my mate Tac was on the phone to me last night with the EXACT same problem when we were all playing COD4
Old Apr 18, 2008 | 05:09 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
Started this morning, wasnt playing anything but the kid was wanting to have a shot and i thought he might have changed a setting or something?? Wasnt sure, its worked perfectly since new and then stopped abruptly!
Old Apr 18, 2008 | 05:13 PM
Stoo's Avatar
Stoo
That's strange mate. Is there any way of pairing it to the machine other than plugging in the cable?
I can't remember if there's an option for that..
Old Apr 18, 2008 | 05:16 PM
Mr.worth's Avatar
Mr.worth
check your contoller settings mate,mine keeps going to controller 2 all on its own,the little red light on the pad should be on no 1.
Old Apr 18, 2008 | 05:22 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
Nope wont pair to the machine unless the cables in!?!?!
Checked the settings it doesnt matter if i put it on controller 1 or 2, still the same. Someone said it might just be the battery but its been charging all day.....
Old Apr 18, 2008 | 05:27 PM
Stoo's Avatar
Stoo
God knows mate. Must be a pain sitting about a foot away from the TV seeing as the cable is so short
Have you tried phoning Sony Support?
If it helps, I know someone who didn't realise the controllers were wireless and sat a foot away from the TV with it plugged in for about a month lol
Old Apr 18, 2008 | 05:33 PM
Stoo's Avatar
Stoo
Right, I've had a hunt and it's NOT a battery issue.
"The wireless controller does not function.
When using the controller wirelessly, if the controller and the system are too far apart, you will not be able to operate the system effectively.
When using the wireless controller, you must pair it with the system and assign
it a controller number. With the system turned on (power indicator on the system
front is lit solid green), connect the system and the controller using the USB
cable, and then press the PS button on the controller.
Check the charge level of the wireless controller battery. When the controller is
used in wireless mode, it will not function if the battery does not have any charge
left. Charge the battery by connecting the controller to the system with the USB
cable.
Wireless controllers for the PS3™ system are not equipped with a vibration
function and will not vibrate when using software that support the vibration
function.
Reset the wireless controller by pushing the reset button on the controller rear with a sharp-tipped object such as a pen"
It seems it's quite common and by resetting it (Tiny reset button on rear of controller) is what's fixed it for most people...
Old Apr 18, 2008 | 05:36 PM
Stoo's Avatar
Stoo
Oh, and interference by wireless speakers also seem to cause problems..
Old Apr 18, 2008 | 06:07 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
Pressed the reset button on the back (once i found something small enough to fit in) and its sorted! Cheers mucka, your a life saver, well 35 quid and a sore arse anyway! lol Didnt even know about the reset button.........
Old Apr 18, 2008 | 06:31 PM
Stoo's Avatar
Stoo
No problem bud. Just glad you got it sorted, google was indeed my friend on finding out the info lol
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
