water injection,how does it
SECS monitor can trigger it if you got one..
just set it so if it sees more than X amount of boost AND above XX charge temps,
it'll turn the pump on. (via a relay )
Passion for Fords!
ive just fitted my kit today...
the pump[ is powered by a switch on the pump itself, so it keeps the line between the injector abd pump under pressure.
just before the injector you have a solenoid, when this opens, the line pressure drops and the pump starts...this way there is no time delay waiting for the pump to build pressure and get to the injector....
my kit runs from the secs monitor, which allows adjustment of switching!
1 Post
I thought with water Injection the mass taken up by air as opposed to water although will give cooler charge, i did read somewhere that being mist and not air, some power can actualy be lost.
Or in other words 30psi of 30 degree of just cooled air, compared to 30 psi of misted air with WI would make less power.
I will find the book i was reading, it explains it a shit load better tyhan i just have
I would like to know more on this myself
Testing the future
Twistin me melon man
i have a "snow performance" water injection kit (from america) on my supercharged zetec, it isnt intercooled and i upped the boost so had to get it to keep the IAT's down.
i've just started running it 50/50 with methanol (which is what the kit is designed for) and the methanol increases the octane rating aswell.
i had it dynoed with a 10bhp gain with it turned on, and that was with 100% water.
mine kicks in at a pre-set boost level. i can buy an add-on controller unit to connect to the maf and have it to kick in at a certain IAT but as my IAT's are so high regardless i'll leave it be for now, its working ok.
The hundreds of pounds spend on a WI set should be spent on more effcient intercooler.
Even on the top speed runs my ACT's are fine with 35 deg seen at end of the runway in about 10 deg ambients.
i'd rather have an intercooler but the supercharger and inlet manifold kit that i got has no way of adding one on, so this is a sneaky way of having a bit more boost out of the system
and it was only £150 for the water kit which was about half the price of aquamist at the time, for the equivalent product.
Passion for Fords!
an intercooler doesnt help when you have been sat in traffic though....infact it makes the situation worse untill the heat from heatsoak has cooled down......
intercoolers get hot unless air is flowing through it....on a road car i noticed this happening alot....wi will help this,by cooling the charge temp during these conditions.
on an american zetec tuning site they are using nitro-methane (50/50 with water) in water injection systems on turbo'd/supercharged zetecs, any thoughts on this?
But if you are stuck in traffic you are not going to need the cooling of the intercooler as you're not going anywhere, therefore not using any boost.......
Passion for Fords!
heres a scenario i came across alot....
come to a roundabout which is very busy......10mins of traffic leading to a dual carrageway...
by the time i get to the dual carrageway charge temps are sky high, as the intercooler has soaked loads of heat from the radiator.....
i nail it up the dualcarrigeway, with high charge temps.....untill a few minuites when they drop off back to normal......at this time im doing 150mph, and needed cool charge temp two mins ago!
Testing the future
Caraholic
That has NOTHING to do with your intercooler, which will have recovered in a matter of seconds, but the location of the ACT sensor (which is in the inlet manifold), which has no air flow to it (hence why it takes longer to recover). If you repositioned your sensor to the outlet of the intercooler, you would have a true representation as to the efficiency of the intercooler and no longer experience the delay .
I run water injection triggered by the ECU which sprays a mist in to my crossover pipe at a specific boost and temperature, if both these criteria are not met then it does not spray
I use it as security to prevent possible detonation rather than to compensate for some major deficiency in my set-up.
Mark RS
12-10-2015 06:01 AM
