Alloy fuel tank pump
Hi guys, what fuel pump would be best suited to an alloy fuel tank on an Fiesta RS turbo.
Do I have to tajke into account, engine power, injectors ect ect
many thanks in advance
you have to take into account how much power you want from the engine
and choose a pump that will comfortably fuel the engine also is the fuel tank in the original position or is it one that fits in the boot?
fuel pump flow is measured in lph(litres per hour) and the bosch flows 300lph is good to about 650 bhp comfortably
you can use a bosch 044 pump thats good to about 600 brake that
m rainbird sells for a good price or you can use a sytec one from demontweeks for the cossie thats a little less
also make sure that your fuel pump wiring is up to the task as uprated pumps normally draw more current and the wiring sometimes cannnot cope
choose a good fuel filter as well that will not cause a restriction in the fuel system
JK12
33
26-04-2021 12:09 PM
jonfoc
16
11-09-2018 05:35 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
