What Oil for a YB and where from?
Old 14-04-2008, 01:21 PM
Ryan
Ryan's Avatar
Default What Oil for a YB and where from?
Need some oil for my YB after its winter hibination.
Mobil 1 motorsport?
What vicousity?
Also where is cheapest to get it?
Car is a road car.
Old 14-04-2008, 01:23 PM
ECOS95
ECOS95's Avatar
10w50 Silkolene Pro S.
oilman on here or http://www.opieoils.co.uk/Default.aspx
Old 14-04-2008, 01:24 PM
warleydaddy
warleydaddy's Avatar
Matt Lewis......
Pete..
Old 14-04-2008, 01:26 PM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Ryan,
Deffo silkolene pro s
Old 14-04-2008, 01:38 PM
R5FORD
R5FORD's Avatar
mobil 1 mate
Old 14-04-2008, 01:46 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Mobil 1 motorsport?
What vicousity?
Car is a road car.
Ryan,
5 litres of ProS is £47 and I can bring it to Santa Pod at the weekend, but I guess that would be too late .
Old 14-04-2008, 01:56 PM
Ryan
Ryan's Avatar
you think mike
Old 14-04-2008, 01:58 PM
Mike Rainbird
Caraholic
Would cost an additional £10 to send it then .
JamesH
JamesH's Avatar
Nah, you'll make it to the pod with no oil Ryan
Old 14-04-2008, 02:01 PM
Lo@der
Passionford Thread Killer
Lo@der's Avatar
Mobile1 from matt lewis mate.
Old 14-04-2008, 02:18 PM
Ryan
Ryan's Avatar
so which oil out of the 2?
Old 14-04-2008, 02:22 PM
Mike Rainbird
Caraholic
There is only one choice .
I USED to stock Mobil 1 and Castrol RS, but after my own experience with these oils (the Mobil loses pressure at high temps and the Castrol unwinds its molecules and expands), plus the extensive tests that Rod carried out, I now only stock the Silkolene. I could easily get either of the others and it IS cheaper, but I only sell things I would be happy using personally.
Old 14-04-2008, 02:27 PM
maxest
maxest's Avatar
I changed from castrol to silkolene and straight away you could hear the difference of cold start up
Old 14-04-2008, 02:28 PM
Ryan
Ryan's Avatar
right best order some now then
Old 14-04-2008, 02:35 PM
Ollie MK5 Turbo
Ollie MK5 Turbo's Avatar
Rainbird are you having a stand at pod this weekend?
I am on running in oil for my zetec turbo atm. I will be drumping it out in 400 miles and want to change tosikolene soon.
J
Old 14-04-2008, 02:37 PM
Ryan
Ryan's Avatar
ordered.
Cheers for the advice everyone, and mike as usual.
Ordered from Oilman
Old 14-04-2008, 02:42 PM
Lo@der
Lo@der's Avatar
ordered.
Ordered from Oilman
Coolio dude, you at action day this sat?
Old 14-04-2008, 02:54 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
I had results of Chemical analysis done on Castrol RS & Silkolene after Topspeed runs. The RS was way out of Spec & had a very high Petrol content & small traces of metal. The Silkolene ran hotter had very low Petrol content & no metal traces & remained within Spec.
Up to that point I did not want to change from Castrol & turned down free oil, the results from an independant chemist changed my mind & I would not use any other oil. Kieth Cowie also uses Silkolene.
Old 14-04-2008, 02:59 PM
KSA-Cossie
KSA-Cossie's Avatar
The best stuff for your cos.
Cossiep
Cossiep's Avatar
Interesting..........
Goes to show what becomes of marketing and peoples perception of the ''big'' names and that they are not necessarily the best option out there.
Old 14-04-2008, 03:43 PM
Ridgey
Ridgey's Avatar
MadRod
so you didn't test the Mobil 1 Motorsport oil ????
What is the significance of fuel and metals in the oil??? Is it not the job of the oil to collect contaminants.
I would have thought it is down to the condition of the engine resulting in higher contaminants, overfuelling leading to fuel in the oil etc etc.
Slightly confused , looking to learn, i do understand a little chemistry.
Old 14-04-2008, 03:59 PM
Mike Rainbird
Caraholic
J
I am on the Norfolk Group stand .
Old 14-04-2008, 04:04 PM
lamb chops
lamb chops's Avatar
Thats interesting Mike as im seeing a drop in oil pressure when shes warm after switching to MObile 1.. Time for a change me thinks
Old 14-04-2008, 04:44 PM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
would like to hear what the "old man" said about mobil 1 15/50....i've only ever used it in a cossie.......................(by the way if u want it at the best price possible phone matt lewis)..........i'd rather buy the best for the engine/car......
Old 14-04-2008, 04:47 PM
JTECH James
Passion for Fords!
JTECH James's Avatar
silkolene is the best cossie oil imo..
Old 14-04-2008, 04:49 PM
Dan
Dan's Avatar
Matt Lewis is HALF the price of fookin Halfrauds!
Old 14-04-2008, 04:58 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Originally Posted by Dave Ridge
MadRod
Metal is obviously wear, we are talking minute wear but wear all the same.
After a Topspeed run on RS Castrol my newly rebuilt engine had 8% concentration of Fuel in the sump this affected the oil & its ability to lubricate. Remember 8.4k. Nitrous & 200+mph are a strain on any engine .
Using Silkolene showed no metal wear, still within Spec as a Lubricant & less than 2% Fuel, that was on Mikes suggested oil.
Opie oils then suggested I use a 5-40 oil from there range which was more expensive it solved all the problems.
Not sure of all the ins & outs but the expensive oil ran hot enough to burn off any petrol by-pass under these extreme conditions the other oils only partly did this & became comtaminated. Remember we are trying to protect an engine not worry about using a bit of oil. Oil pressure dropped as they said it would, showing that high oil pressure does not mean good lubrication.
Please dont ask any technical questions of me, cos I dont know or care about any other technical details.
ps. If i had suggested to Mark Shead that I was going to use Mobil 1, he would not have put the engine in the car & probably used it for his hair.
Old 14-04-2008, 05:08 PM
LHD220Turbo
LHD220Turbo's Avatar
interesting thread
Old 14-04-2008, 05:11 PM
JamesH
JamesH's Avatar
Rod,
Sorry if I'm being short sighted or something, but surely the oil would not get chance to have any fuel in there is the fuel was spot on?
Confused, and willing to learn
Old 14-04-2008, 05:26 PM
pete mcrash
..............just when mobil 1 15/50 say's it's developed buy cosworth......u tend to think it's up to the job........
Old 14-04-2008, 05:32 PM
Ridgey
Ridgey's Avatar
Mobil 1 for me i still thinks.
Old 14-04-2008, 05:38 PM
CossieRich
CossieRich's Avatar
Seriously after talking to Rod and Mark and reading about oils from oil man on here, there is no way i would use mobil 1 or castrol rs. Just Silkolene pro s
Old 14-04-2008, 05:39 PM
CossieRich
CossieRich's Avatar
Why, when there are oils that are better and have been proven better?
Old 14-04-2008, 06:05 PM
pete mcrash
mobil 1..........fukn ell i've got loads in the shed.............i change it every 3-4k (big sump aswell)................(foreign rs told me aswell)............time for a change then
Old 14-04-2008, 06:21 PM
Ima Racing
Ima Racing's Avatar
...jeezs....in a road car normal mineral oil is fine!...infact even a track car dont need anything much better!......do you honestly think you would notice any longevity difference in your engine?...Rod maybe needs a better quality lube due to extreme coinditions...but for most its all a con really as the actual quality of oil only dictates the oil life..ie you can go upto 20k miles before any degrading on for example mobil 1 and no cossie has that done..more like every 3k its changed a waste of money!...Having said that my merc runs mobil 1 and the f-car shell helix but thats only because they are proper engines.. LOL
Old 14-04-2008, 06:30 PM
Mark Shead
Mark Shead's Avatar
Originally Posted by James90RS
Rod,
Just think off 800 to 1000hp of blow by, This is where the fuel came from.
Mark
Old 14-04-2008, 06:37 PM
pete mcrash
Mark
....understood....but what about every day cossies....???
Old 14-04-2008, 06:41 PM
Mark Shead
Mark Shead's Avatar
You should have next to none, I only use Pro S now in everything.
Mark
Old 14-04-2008, 06:47 PM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Mark
Seconded. I have tens of YB customers whom have had their oil consumption halved and rattly followers silenced by Pro s too.
Old 14-04-2008, 06:50 PM
BigErn
BigErn's Avatar
Iva always used Semi Synthetc Texaco Havoline 10/40 without any problems. Oil changed every 5k miles, topped up around a litre a week though on my last one as it burned a bit being caned for 400 miles a week, so it was always clean anyway, lol. Plus as an added bonus its only £14 for 5 litres from my local Asda .
Why buy expensive oil to have to top up and change it that regularly, IMO its a waste.
My cossies are driven in anger 90% of the time they are being used and Im yet to have the oil cause any problems.
My 2p's worth.
Quick Reply: What Oil for a YB and where from?
