Rover 200 Starting problem
Old Apr 7, 2008 | 07:30 PM
davidnormanuk's Avatar
davidnormanuk
Default Rover 200 Starting problem
Hi all,
Obviously this is a Ford Forum but there seems to be so many people on here who are helpful with all sorts of different makes and models I thought I'd give it a go.
I have just bought myself a Rover 200 on a T plate which needed the clutch replacing. The car ran fine before taking the gearbox off.
Now that everything's back together the car fires but will not start. There is fuel and the spark is very good but the car just will not run.
Any help or suggestions would be appreciated.
Dave
Old Apr 7, 2008 | 07:32 PM
L33 BYT's Avatar
L33 BYT
Main vehicle earth re-attached?
Stater solenoid connectioned re-attached?
Old Apr 7, 2008 | 07:39 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Originally Posted by davidnormanuk
Hi all,
Dave
You didn't change the flywheel did you???
Old Apr 7, 2008 | 07:41 PM
davidnormanuk
The car turns over and fires but doesn't run. I'll double check the earth cables though.
Old Apr 7, 2008 | 07:43 PM
davidnormanuk
No, I left the flywheel in position and just fitted a new clutch. I figured it would be something daft which I'm missing.
L33 BYT's Avatar
L33 BYT
As Martin says. Flywheel is this the original fly wheel or different?
L33 BYT's Avatar
L33 BYT
Whoops too late
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
cos elle
Sep 1, 2015 06:48 PM
nick8saff
Aug 16, 2015 05:35 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
