power steering leak!!!
my cossie has always had this the pipe from the power steering fluid resivour to the pump has always weeped!i changed the pipe and clip a couple of years ago,which never cured it!!as i now changing everything just wondered if anyone else has had this problem and how u cured it?
Mine does it too
Mine is leaking from the joint on the return pipe
I've been told that I can cure it by cutting it off and putting the rubber hose onto the hard pipe with a jubilee clip but I haven't got around to it yet.
take off your old hoses..then take them to ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
http://www.pirtek.co.uk/pitstop.php
get some fresh spanky ones made up![Top](https://passionford.com/forum/images/smilies/smile011.gif)
![Content](https://passionford.com/forum/images/smilies/content.gif)
OCD Victim
It is normally the bottles themselves. When you do the clip up, it squeezes the bottle connection slightly, allowing it to continue weeping.
Try and find a metal insert they you can slide into the connection (must be a snug fit) and then try connecting it back together. This should prevent the bottle connection from crushing and therefore prevent the weep.
It is a common problem with expansion bottles for coolant systems. Most manufacturers now put a small metal insert into the hose connections, especially on the smaller-bore return ones. Same principle would apply to PAS bottles though.
![](http://img.photobucket.com/albums/v291/sooty52002/new%20smoke%20pics/Image006.jpg)
good idea
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
OCD Victim
07-10-2015 12:56 PM
