cossie idle valves
04-04-2008, 07:05 PM
cossie idle valves
When these things go wrong where can you get new used ones from apart from ebay or cossie breakers.
04-04-2008, 07:15 PM
saff is working!!!...atm
stick it in some diesel over night..........then try it
04-04-2008, 07:17 PM
Passion for Fords!
new used ones?
what like brand new second hand
04-04-2008, 07:20 PM
Passion for Fords!
Quote:
Originally Posted by
pete mcrash
thats fantastic advice,as the valve will hold some diesel,and induce it into the air stream.....det anyone
04-04-2008, 07:23 PM
Ha Ha , i have seen the mistake.
04-04-2008, 07:24 PM
04-04-2008, 07:26 PM
Passion for Fords!
lancia use the same valve.....pj motorsport had a few brand new ones at 200 quid....
04-04-2008, 07:29 PM
Thanks i will give them call
04-04-2008, 08:40 PM
JTECHSAFF
..........oh i forgot about twats like u........sorry i should have said let it dry and apply a little oil in the "sprinngy bit"......
04-04-2008, 08:49 PM
Passion for Fords!
what oil? theres one common type you should NEVER use......
but twats like you wouldnt know which,or why......
05-04-2008, 07:07 AM
..............why dont u fukin' tell him then.....gobshite...
05-04-2008, 07:26 AM
are u talking about wd40.......cos there's been a thread on here,and people say thats what they use with no problems..........i used a dribble of engine oil......(if thats ok with u..??)
05-04-2008, 08:43 AM
Passion for Fords!
wd40 should never be used, because,as any intelligent person will tell you,it evaporates in a few hours,and leaves a grease like residue....making the valve sticky.
a thin oil is best.
and the best thing to clean them with is a solvent based cleaner like carb cleaner,as it evaporates away to nothing,
but its fact that 90% of so called iscv problems,are not directly related to the valve itself....people seem to think a surging idle is a iscv fault....but that normally means the valve is working perfectly well,rasing and lowering idle......its an engine setup fault more often
05-04-2008, 09:07 AM
what about........olive oil (extra virgin)....thats pretty thin.......or maybe tea tree oil....thats thin as fuck.........
06-04-2008, 04:08 PM
Everybody getting on well together as usual then. Thanks to you both for the info.
06-04-2008, 07:11 PM
Ha ha pete nice one hee hee.
06-04-2008, 07:16 PM
whats it doin? not the tps is it?
15
07-10-2015 03:43 PM
IainRS1700T
25-09-2015 06:44 AM
RSmark84
13-09-2015 01:29 PM
routemaster
07-09-2015 05:27 PM
cossirob
03-09-2015 09:17 PM
