Live mapping tutorial by Stu.... Discussion Required
Old Feb 28, 2004 | 08:13 PM
  #241
scottbrown's Avatar
scottbrown
so is "getting into" an ecu along similar lines of "hacking"? ie breaking there codes etc.
how long can/does it take to get past security? ie does it cost u alot of ur time etc?
wot if i turned up to a pre booked mapping session and u had never mapped a car the same as mine before?
Old Feb 28, 2004 | 08:14 PM
  #242
markk's Avatar
markk
Stu @ M Developments,
cambus
canbus !!!
from a quick count i can tell you that there is no fewer than 7 ecm's as a minimum on todays cars , all have multi comm patterns via wired pairs as production data communication , all with digital atributes , with lots of 'if' possibilities !!
and as for the data speed through can , well , let s put it this way , alot of the diagnostic software thats about to day , has to have some form of converter to in effect slow the data thats in the syatem so it can be read , wether it be primary or secondary comm speed !!
Old Feb 28, 2004 | 08:16 PM
  #243
markk's Avatar
markk
scottbrown,
do ya not think they will ask wot u got ???
but , ive not yet been told 'sorry cant do that' in the many years ive been dealing with msd !!
that includes diesels etc etc ! (and vans )
Old Feb 28, 2004 | 08:19 PM
  #244
Stu @ M Developments's Avatar
PassionFords Creator
scottbrown,
No, its not so much hacking as investigating and drawing on other experts in certain fields to get a global solution.
On 99% of stuff we can just remove the eprom itself, put it in the programmer and extract its data...
Then we begin the process seen throughout this post of sourcing maps etc etc etc.
Once all that is done, we have found the maps and modified em, we cant just burn it back to a chip and rteplace it, as i presume most of you would expect?
Oh no.. we then have to get past the checksum security built into the ecu..
Alter 1 single digit in that file, and the ecu wont allow the engine to start....
the bit youve just read 5pages of, is the extremely simple bit
scottbrown,
Well we did an 04 Megane DCi on Monday and that took about 11hrs if that helps?
(Tricky little thing actually.. keyless entry, the lot )
Old Feb 28, 2004 | 08:25 PM
  #245
I know its a CaNbus you git.... bloody N's next to the M
Old Feb 28, 2004 | 08:32 PM
  #246
scottbrown's Avatar
scottbrown
answers stu! and in easy terms for us lay men to understand
couple more questions for u..
so is it legal for u to "break into" for example a megane ecu and make changes to the map?
how easy is it to put bk to standard for example for warrenty purposes?
cheers
Old Feb 28, 2004 | 08:34 PM
  #247
Yes. Its legal in so much as the "owner" of the equipment asked us to change it, so we did.
putting back to standard is usually a simple job.
Old Feb 28, 2004 | 08:36 PM
  #248
scottbrown's Avatar
scottbrown
cant think of anymore questions right now but i am sure i will
cheers
Old Feb 28, 2004 | 10:59 PM
  #249
PJay's Avatar
PJay
Some more good info there
Old Feb 29, 2004 | 12:58 AM
  #250
Bloody ell.. 2100 views
Not bad at all in only 4days
Old Feb 29, 2004 | 01:01 AM
  #251
PJay's Avatar
PJay
good thread thats why
Old Feb 29, 2004 | 12:14 PM
  #252
James's Avatar
James
Excellent thread, i've been here for about the last three hours reading everything and it's been a bloody good insight into it all as i really didn't have a clue, still don't on some of the things mentioned but it's still a interesting thread
Old Feb 29, 2004 | 05:54 PM
  #253
GARETH T's Avatar
GARETH T
what would be wicked if if you uploaded the sound of a car just starting to det before retarding the ignition
Old Mar 1, 2004 | 01:57 PM
  #254
scottbrown's Avatar
scottbrown
when u live map a car stu, say for example its 9am mid of january and its -2 outside, cos of the cold air the car is less likely to det?? but wot happens then when i drive my car in august and its 35 degrees outside??
how do u allow for this?
Old Mar 1, 2004 | 02:15 PM
  #255
foreigneRS's Avatar
foreigneRS
Testing the future
simple, you have a table for ACT to take account of this. as ACT increases, you retard (or advance less) the ignition timing as this table (taken from a demo version of the SECS S8 management software shows:
Old Mar 5, 2004 | 11:44 AM
  #256
Someone said they had saved all this to a Word doc or similar i recall?
May i have a copy please, as it will make a damn good guide for my updated website im working on today
Old Mar 5, 2004 | 12:48 PM
  #257
Old Mar 5, 2004 | 12:49 PM
  #258
Smit's Avatar
Smit
The 60ft Launch King
belongs in the techy essay bit
spooky mind as i've just read the one about map sensors
Old Mar 5, 2004 | 01:00 PM
  #259
TM's Avatar
TM
On the SECS Ignition retard for air temp is it not based on Load as well.
Old Mar 5, 2004 | 01:02 PM
  #260
ECU Monitor Enthusiast
That version of software is yonks old.
It is based on load aswell on the final release version.
Old Mar 5, 2004 | 01:06 PM
  #261
TM's Avatar
TM
Old Mar 5, 2004 | 01:20 PM
  #262
None of which helps my Word doc hunt guys
Old Mar 5, 2004 | 02:30 PM
  #263
Page 2
Old Mar 5, 2004 | 04:13 PM
  #264
Page 2 again
Old Mar 5, 2004 | 05:07 PM
  #265
GARETH T's Avatar
GARETH T
i wouldnt know how stu
Old Mar 5, 2004 | 05:17 PM
  #266
Someone commented on how many word pages it took up...
never mind.. il start copying it mayself later... thought it would make an interesting section for my website
Old Mar 7, 2004 | 12:43 PM
  #267
Panza's Avatar
Panza
Old Mar 7, 2004 | 01:03 PM
  #268
PJay's Avatar
PJay
When you're mapping the YB cosworth engine (or any engine really when I think of it, but let's say the YB to simplify a bit).
What is the mechanical factors that limits power output ?
Let's use a stage 3 escort Cossie as a first example and another one with anything you like on it to make as much power as possible (still 2 litres).
I really like this post.
Airflow is the one thing that determines engine power
Old Nov 29, 2004 | 12:26 PM
  #269
Right guys, i an attempt to fix this damn topic weve had to delete the last page of replies... sorry
Old Jan 3, 2005 | 02:53 PM
  #270
Lets get this going again, beats all the arguing
Old Jan 3, 2005 | 03:29 PM
  #271
Chrissy_bwoy's Avatar
Chrissy_bwoy
cracking topic!!!!
read thru the lot
very interesting as mines gonna go off to be done soon, but in reading the EECIV bit..... im probly gonna be hated
Old Jan 3, 2005 | 11:21 PM
  #272
Azrael's Avatar
Azrael
By the way - Stu I don't know if it;'s the right place to write that but you webside still says you can map EEC IV and you say you can't - one version must be changed
Old Jan 4, 2005 | 09:38 AM
  #273
JesseT's Avatar
JesseT
Mapping the fuel map is rather straigthforward with the correct tools, but I've always wondered how the tuners tune the ignition maps? Of course watching for detonation is one thing, but that really helps only in one part of the map. Do tuners usually play with the not boosted part of the ignition map much at all?
Also an original ignition map of a RST would be interesting to see.
Old Jan 4, 2005 | 09:44 AM
  #274
I can map EEC IV and V mate
Old Jan 4, 2005 | 09:45 AM
  #275
Hi,
I tend to spend FAR more time in teh off boost areas than i do teh on boost areas of the map. I personally class driveability, power delivery and fuel consumption as equally if not more important than outright horsepower.
Old Jan 4, 2005 | 10:27 AM
  #276
foreigneRS's Avatar
foreigneRS
Testing the future
good question Jesse
like you, i agree that if you've got a reasonable wb lambda sensor and controller it's relatively easy to setup the fuelling reasonably accurately, but what about the ignition?
what tools do we need (for example det cans, knock sensors, EGT probes, accelerometers etc) to be able to setup the ignition maps well? and what are we looking to do in all areas of the maps? for example on max boost we want to advance for power but not too much for det, but what about coming on boost (where we may want to run not as much advance for higher egt temps to give energy to the turbo for faster spool up, for example), around idle, below idle (big advance to get speed up again?), cruising, gentle acceleration, off throttle (cut ignition and fuel?).
many questions in there i'm sure stu, but we'd appreciate your experience and teaching as much as possible (and any other tuners, pro or diy)
Old Jan 4, 2005 | 12:07 PM
  #277
JesseT's Avatar
JesseT
Hi,
I tend to spend FAR more time in the off boost areas than i do the on boost areas of the map. I personally class driveability, power delivery and fuel consumption as equally if not more important than outright horsepower.
Seems then that you do your work properly.
Old Jan 4, 2005 | 01:48 PM
  #278
Azrael's Avatar
Azrael
Now I'm really confused... there must be your other self speaking to me from time to time or something.
I asked you a couple of times about mapping EEC IV in my Escos and you said no - you've got the equipment and knowledge but to much R&D to do it hmm...
The only explanation behind all this is that Escos EEV IV is something different then EEC IV on other Fords....
Old Jan 4, 2005 | 01:56 PM
  #279
Azrael,
No, its because you were talking about fitting larger injectors and turbo as i recall... thats a different kettle of fish to mapping on existing equiptment
Il address the other questions later as theyre not so easy to answer.. keep em coming as i enjoy this topic
Old Jan 4, 2005 | 01:59 PM
  #280
Azrael's Avatar
Azrael
Azrael,
But inside limitations of existing sensors it is doable no problems? Injectors I think last until about 300HP?
