Live mapping tutorial by Stu.... Discussion Required
Old Oct 15, 2006 | 06:13 PM
  #441
xr2i-carl's Avatar
xr2i-carl
mancansome condesne this post down into bitesize chunks
its way tooo much to read
carl
Old Oct 16, 2006 | 11:33 AM
  #442
Stu @ M Developments's Avatar
PassionFords Creator
Old May 13, 2009 | 07:29 AM
  #443
series_one_rst's Avatar
series_one_rst
wow! great thread!
Old Dec 27, 2009 | 02:49 AM
  #444
HockeyNomad's Avatar
HockeyNomad
bit of a bump from the past, but ive just read this through again,
as ive spent a lot of time looking into engine management recently as its nearing crunch time, the car is nearly ready to return to the roads, and i want to know as much as possible about whats going to happen and different systems capabilities etc etc,
one thing ive been wondering is
off the shelf handheld odb2 flash map systems, what is it they exactly do, for example, over on the rsownersclub forum for the focus rs mk1 its popular to change the ECU base map from AF to the older AE software which apparently can only be done using fords WDS system, and then use a bluefin or dreamscience unit to load a flash file via the odb port,
so what i am wondering is is there only certain parameters that can be changed flashing via the odb2 port ie there are unchangeable protected areas that only the wds system is allowed access to,
just thought it might be a relevant question with the popularity of these handheld units,
cheers,
Andrew
Old Dec 27, 2009 | 09:01 PM
  #445
turbotoaster's Avatar
turbotoaster
i really enjoyed reading that, even if it did take most of the day!
one question i wondered, is in alot of maps before the turbo starts making positive boost you can run alot of ignition, basically to give the car better off boost power.
now they say by retarding the ignition you make the map more safe and also increase the the EGTs, higher EGTs have more energy and help to spool the turbo up.
So if you ran alot of retard could you make the turbo spool earlier to help with massive turbos, make your very low end a bit pants to drive but gave you a larger powerband as your turbo would be on song earlier.
Or am i talking complete rubbish and not picked up what people have said properly
Old Dec 28, 2009 | 04:10 PM
  #446
AlexF's Avatar
AlexF
you right - but you are only considering the enigne mapping and not how turbos work...
In short its more complicated than that... Look up boost threshold and lag on here
Old Jan 6, 2011 | 10:14 PM
  #447
BTTT for an interesting topic for new members to read.
jay030787
Sep 25, 2015 01:38 AM
