Is Bernie aka Gearbox man still about?
hi dave
what do you mean slow ? at the end of the day your mainshaft was sent away not by bara did martin not send the mainshaft of to be treated ? if he did was has that got to do with bara ? bara got your main shaft send to him when it was done he soon built your box asap when he got it
marco
Guest
Posts: n/a
hi dave
marco
marco
What l should of said is
Broke gearbox at Daddy Trash
Waited 6 weeks phoned martin, Martin then called back will know in another 6 weeks
After 12 weeks called still no answer on shaft, Martin then said go back to standard shaft.
So went back to Standard shaft and had it frozen. Martin contact me to say he is going to collect box.
Same day get a call to say that Bara wont give box back unless the uprated shaft is paid for, Waited 16 weeks to get a answer on that to find out from Bara the shaft had still not been tested.
In the end Bara agreed to give us back the box and not hold me or martin for the uprated shaft.
But apart from that issue he turned the box around in 2 days when l need it for Daddy Trash..
But as you all know, your as only good as your last job and really didnt want to wait 16 weeks for my box to come back
Dave
dont think bernie uses PF anymore now he's got a beemer instead... lol
was up there a few months ago getting my diff sorted on the M3, seemed it didnt like trying to out-launch a scooby
hi dave
well you should have said that on your first post ...rather than people guessing what you are on about , if you have got something to say that you are not happy then just say it , why beat around the bush ????
with the uprated mainshaft that you are on about these are not made by bara
and your mainshaft was sent on to the designer to find out what was the problem/fault with it ......if he takes along time then shorly thats not bara's fault
again there was no point in fitting an other uprated mainshaft in you box untill he finds out whats the problem
even to this day he hasn't found out what was wrong with your mainshaft
theres loads of happy customers out there that have had stuff done by bara which has been top notch very quick service and turn around due to having the parts on the shelf
im not defending bara the mainsahft issue is out of his controll
marco
marco
chowfornow
14
05-01-2019 09:01 PM
