WOT 1bar 14.0 afr no det?
just got a wideband and at WOT full load, 1 bar and 14.0afr
no det!
is that possible?
with the afr being so lean?
no det!
is that possible?
Where abouts in the rpm range is it at 14, surly not all the way to the limiter?
Does it not transition from 14 on first application of WOT down to 11.5-12 as revs start to pick up?
Also what gear were you testing in it and where is the probe mounted(distance from turbo)
Testing the future
hopefully chip will explain it, but it's got little to do with the change in density of the air by the reduced temperature, and more to do with the fact that a reduced pressure drop will allow a greater mass flow of air
I wouldn't drive it until you can get it mapped again.
If you need a quick fix you could probably send me or chip your fuel map and afr log so one of us could make some quick changes to get you out of the danger zone.
wheelwizardrefurbs
22-09-2015 05:45 PM
