Saff Cosworth 4x4 fuel pump relay
Does anybody know where it is???
My saff wont start, the starter motor sometimes sticks so i towed it round and round and it wouldnt bump this time, once i turned the radio off i realised the fuel pump isnt priming, when you put a seperate power source straight to the live terminal the pump comes to life thou!
Also after towing it round i took the plugs out and they are all dry, so i want to find the fuse and relay so i can check them but my wiring diagram is different to whats actually in the fuse box.
Im going to put a wire to the starter as well to see if it is sparking, if it aint im assuming the immobiliser is fooked, but it locks and unlocks ok, and when i press the anti hijack button on remote it goes off as it should.
Is givin me the arse ache now LOL.
Any help or ideas welcome, thanks for looking....
on a 4x4 cosworth
the fuel pump inertia cut off switch is in the drivers floor kick panel.. you need a posi drive screwdriver to undo it and reset it
ponder why ford thought.yes heres the reset button.but you need a screwdriver to get to it
no words needed
no words needed
If its located in the spare wheel it could get rusty inside so ift nothing else works try bypassing it with some wires just to check if its the culprit or not.
kosienutter
31
22-08-2015 09:55 AM
Anutternutter
21-08-2015 06:07 PM
