Thread M16x150
Old Mar 19, 2008 | 08:25 PM
Spiky's Avatar
Spiky
Default Thread M16x150
i'm not the best when it comes to threads.
can i assume correct thst this is metric? does it have an imperial thread like 1/8npt???
or would they be totally different?
as this is the thread pattern on the oil pressure switch on my engine
and most gaauges come as 1/8npt so would i need an adapter??
i think i do, but having a blonde moment
Old Mar 19, 2008 | 08:42 PM
vroomtshh's Avatar
vroomtshh
M16 is metric. Are you sure its by 150 though? Not 1.50?
Old Mar 19, 2008 | 08:56 PM
Alan s1's Avatar
Alan s1
I was going to say thats some thread 150 lol
Old Mar 19, 2008 | 08:58 PM
Spiky's Avatar
Spiky
it's what it says on peugeot parts program
Old Mar 19, 2008 | 09:03 PM
Red16's Avatar
Red16
sounds like its M16x1.5 which is the same thread size as the banjo bolts that screw into cossie turbo's for the water cooling
Alan s1's Avatar
Alan s1
M16 = 16mm and 150= 15cm
Old Mar 19, 2008 | 09:09 PM
Spiky's Avatar
Spiky
this is what is says
15
1131 82
01
OIL PRES SWITCH
DIAM 16X150
- INJECTION XU10J4RS UNTIL RPO No. 07874
+ 0164 54 (1)
1131 C5
01
DIAM 16X150
GR - GREY
- INJECTION XU10J4RS SINCE RPO No. 07875
Old Mar 19, 2008 | 09:17 PM
Red16's Avatar
Red16
that info's a bit vague spikey... worth a phone call to peugeot tomorrow imo
Old Mar 19, 2008 | 09:22 PM
Red16's Avatar
Red16
threads are normally described as M16x1.5 for instance which is what yours could well be... the 16mm is the diameter of the thread in mm and the 1.5 bit is the pitch of the thread also in mm
if you have a Pirtek in your area pop in and they'll have any adaptor etc you could possibly want to buy.
Old Mar 19, 2008 | 09:28 PM
Spiky's Avatar
Spiky
i have
cheers will pop down,as have an old sensor for my engine so they an match to that
Old Mar 19, 2008 | 09:52 PM
Twellsie's Avatar
Twellsie
M16 = 16mm, when the pitch is omited it means that you refer back to ISO 261 (or might have been 262, i cant remember) so it will be a coarse thread 2mm pitch, X150 is obviously not the pitch so it will refer to the length being 150mm.
so in short M16, coarse thread (2mm pitch) 150mm long
Old Mar 20, 2008 | 08:22 AM
vroomtshh's Avatar
vroomtshh
I would disagree. I think its bad wording from peugeot. No way is the bit hes talking about 150mm long.
Old Mar 20, 2008 | 08:32 AM
Spiky's Avatar
Spiky
i disagree too,
as it's only 10mm i'd say
Old Mar 20, 2008 | 09:18 AM
vroomtshh's Avatar
vroomtshh
If thats the case, then its gonna be M16 x 1.5 pitch. So standard M16. An adaptor should be easy to pick up for that.
Old Mar 20, 2008 | 09:22 AM
Spiky's Avatar
Spiky
yeah seen a few m16X1.5 to 1/8npt, so thats should be ok
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
