Puegeot 206
Puegeot 206
Mornin,my partner has a 1.4lx 206 petrol which has just recently started mis firing,there is no sign of head gasget and have changed the plugs and coil pack which thought was going to cure it and hasnt,just wondering if anyone any ideas???
Hi guys this problem is still going on,wasnt the coil pack and plugs where fine,then found out it was the first injector so replaced that and now is the idle is terrible sounds like is missing and when rev sometimes stick at 2k revs,have been told to check the stepper motor any other ideas?????
Evening Guys still not on the road ha ha,have been told that another fault for this could be the engine coolant sensor anyone any ideas as have been also told that without the engine management system on then a diagnostic check is out of the question also?????
when my ex gf's 206 quiksilver done that as mentioned above it was the coilpack and 2 injectors which gave up the ghost,
try another coilpack from a car u know is working properly, if misfire goes you know the problem is that.
HTH
HTH
