Zetec into Mk4 Escort..... wiring loom etc...
Fast Ford snapper
Fitting a 2.0 silvertop into my MK4 Escort just now.
EDIT:
update as posted below:
Not in place yet, but getting there!
Old CVH engine out and Zetec alternator in situ with the CVH mount and just the belt to go on now...
Wiring loom now to be sussed....... seems to be too many connectors and no obvious power feed.
Anyone got a wiring diagram/guide/tips?!
Need to know what belt to use if removing the powersteering pump, also if anyone has a diagram of what route the belts (or belts) that would be a great help.
The engine was already converted to run in a MK6 Escort, but unsure if the water pump etc has been changed from teh original setup....
Any idea/help much appreciated!
EDIT:
Fast Ford snapper
I and was going to phone you as well as I thought you'd know
Nice one, we worked this out soon after I posted.... CVH alternator bracket going on, and XR2i zetec belt.
There was also meant to be a air con pulley on the engine too but it had been robbed.... so that confused things a bit.
Will check part numbers with the above number too, cheers!
Fast Ford snapper
all depends on wot alternator you use as to wot belt to put on.i am using a cvh alternator on my mk2 fiesta with 2ltr 16v turbo ,the belt i use is a 6pk 960 fits like a glove
Fast Ford snapper
JK12
33
26-04-2021 12:09 PM
chris m1
07-09-2015 08:02 PM
