Will cosworth vernier pullys fit me zetec cams?????????
PassionBMW.com Member
Fugeass Zetec ones are fine mate honestly. peice of fooking cake to setup if you buy the propper tool for them.
Put bottom end to TDC (No1 Cyl)
Lock Cams with the tool.
Loosen Off pulleys so they spin free.
Add Belt
Tension Belt
Hold the pulleys as they are with the lever tool, and do the bolts up. Repeat for other pulley.
Remove Cam Locking Tool
Away you go.
Add Belt
Tension Belt
Away you go.
cheers phil, well, ive fitted and timed zetec cams loads of times now, but i was thinking about getting some fast road cams, they need setting to 110 deg ATDC on the inlet, and 110 deg BTDC for zorst timing.
i just thought it would be better to get verniers... lol
JoeyBoyden
04-01-2024 02:36 PM
lockie
31-07-2015 10:03 PM
