AMAL VALVE QUESTION
FAIRY CAKE
AMAL VALVE QUESTION
can you run without one? well i know you can cos i have seen it
basically it has the pipe from the actulator going to the bottom feed on the turbo/looping
whats that all about
FAIRY CAKE
aye its just running off the preload,only 7ish psi
cant for the life of me think why its been plumbed in this way,no amal and no bleed valve
compressor to amal, amal to actuator, amal bleed to airbox/cone/atmos
if your on about your car pops you must run the amal to a)bleed enough air off for the mid range boost and b)knock the boost back at higher rpm
FAIRY CAKE
pmsl @ mine
i dont touch mine after karl has i run an amal
but this is as i said not running a amal or bleed valve at all, the pipe goes staight from the actuator to the compressor and the airbox is blocked off,running 7ish psi,engine was rebuilt and has just done its running in,so due a set up,just cant get my head round why its plumbed in this way
lol might have guessed
we ran my engine in like that depends on what actuator you have and how you load it, mines a -34 and ran the min 3mm (half hole) preload to run it in, thats about 15psi...how times have changed lol
well mine is set up similar all piped that go to amal valve have been took of it and just tpieced them together no bleed valve or nothing i found the amal valve in the boot do you think i should put it back on????
mines running without amal and bleed!...running 16psi..(know its an escort but still counts i guess)...would i be better off getting a bleed valve then????????
Mine was running a Pipe from compressor housing to actuator eliminating the AMAL. I have since reconnected the amal us per STD form and it runs a LOT better now.
eil, wont cause faster spoolup, infact if anytihng itll be slower
all youre doing here is letting the actuator see ALL the air, so you only get the actuator preload (so if its 7psi thatll mean its ona -31 actuator)
no real reason to do it this way imho, but its not exactly "bad" just means you get naff all boost.
probably done this way so that the car's always in LOW BOOST mode for runining in, stops it bosting too high
bounce, bounce, bounce
Mine didn't have an amal valve when I bought it, just all 3 pipes t'd together. Didn't look right to me so I put an amal on sharpish. Can't say I've noticed much difference to be honest
all am amal valve is is a T peice internally! its just that you can switch it on/off to stop it openeing/closing the middle Ted off bit to the airbox...
a normal T peice is crude, but it will work.
I know but I would assume an amal would have a degree of electronic control over the boost characteristics whereas a T piece wouldn't, obviously. That's why I would have expected something a little different when re-attaching it.
just finding my feet
on erst's they remove the amal and then repipe to the crossover to hold steady boost
look in the tech section at the bottom for the post about amal valves and that will explain
the bleed needs to be jetted to allow boost spike , no small jet and ya get get a less spike and the one to the actuator when its jetted allows slower opening of the wastgate
hemce why my car feels soo slow
lee you either 1) had a -34 but didnt realise 2) were running SHEDLOADS too much preload on the actuator
std actuator: 2-4psi (ish)
-31: 7psi ish
-34: 14psi ish
theyre the tensions on the actuators
-31: 7psi ish
-34: 14psi ish
