GTi Help Needed Please........
Old Feb 28, 2008 | 06:27 PM
Jobbo's Avatar
Jobbo
Default GTi Help Needed Please........
Could someone help please, for the last couple of days our 1998 Escort Gti has been trying to stall on tickover, when you first set out in the car it seems to be ok but after 5-10 mins in the car when you put your foot on the clutch the revs seem to drop right down and then appear to bounce back up, this will continue for a while and the revs seem to bounce up and down trying to stall then it seems to level out again, could someone please give me some idea what is wrong?
Many Thanks in advance
Jobbo
Old Feb 28, 2008 | 06:36 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Sounds like your ISCV.
Old Feb 28, 2008 | 06:37 PM
babscossie's Avatar
babscossie
its prob going to be an air leak on the inlet side of the engine or poss the iacv needs taking off and cleaning out.
Old Feb 28, 2008 | 06:38 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
iscv all the way!!!!!!!!!
Old Feb 28, 2008 | 07:11 PM
Jobbo's Avatar
Jobbo
Will the ISCV need replacing?
Old Feb 28, 2008 | 07:13 PM
Dangerous Malcolm..
You can try cleaning it and see if that helps.
babscossie's Avatar
babscossie
most of the time you can get away with cleaning then out.
Old Feb 28, 2008 | 07:14 PM
BM08's Avatar
BM08
clean it mate, had this happen on my old GTi.
Give it a good spray with oil or something, that fixed mine
Old Feb 28, 2008 | 07:23 PM
Jobbo's Avatar
Jobbo
Many Thanks Guys,
Is the car driveable as it is or will it die on me, I wont be able to have a look until the weekend as I start my new job tomorrow?
Old Feb 28, 2008 | 07:55 PM
babscossie's Avatar
babscossie
wont cause any damage to drive it. may just stall at times
Old Feb 28, 2008 | 07:58 PM
Dangerous Malcolm..
Just keep restarting it fella. It's a fiddly arse of a job to remove, and you'll have to do it from underneath. You should really get a new seal to be on the safe side..
KW-rscos's Avatar
KW-rscos
Really dont want to sound like a dunce, but where is a the ISCV?
Old Feb 28, 2008 | 08:00 PM
Dangerous Malcolm..
Under the inlet manifold on 1.8 and 2.0 zetecs.
Old Feb 28, 2008 | 08:01 PM
lammylama's Avatar
lammylama
its tucked away nicely under the inlet manifold and a bastard to get to......i just took the throttle body off,makes life a lot easier and a good spray/clean with WD40 sorted mine out.
Old Feb 28, 2008 | 08:06 PM
Dangerous Malcolm..
Found THIS, might be of some help.
Old Mar 1, 2008 | 09:38 AM
Jobbo's Avatar
Jobbo
Thanks again Guys!!
JoeyBoyden
Jan 4, 2024 02:36 PM
Kyle Langford
27
Aug 5, 2019 07:54 PM
Rs_Motion
Escort MK 5 / MK 6
Jan 7, 2016 10:38 PM
mrice0107
Aug 21, 2015 07:55 PM
col93saphcos
Aug 7, 2015 03:21 PM
