cossie sensor kit?
Old Feb 28, 2008 | 01:11 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Default cossie sensor kit?
got a full engine bay sensor kit to hopefully cure my problems, are these easy enough to fit? especially phase sensor (does dizzy have to be removed completely?) and crank sensor?
cheeRS
Old Feb 28, 2008 | 01:49 PM
xr4x4rs's Avatar
xr4x4rs
4wd or 2wd?
Old Feb 28, 2008 | 03:07 PM
Zetec_mk4_XR3i
oops sorry - its a 4x4 with the green topper (92/j plate)
Old Feb 28, 2008 | 03:50 PM
xr4x4rs's Avatar
xr4x4rs
most are easy to change
the hard ones are going to be the 2 water sensors at the back of the head behind the inlet
its proberbly easier to remove the inlet manifold to do these
phase sensor is easy
remove dizzy cap, rotor and cover, and then its just 2 screws that hold it in
make a not of which way round the connector goes on the pins though, i dont know the gap you should check it to though i carnt remember, but im sure someone will say what it is
cran sensor is just 2 nuts off the sump and undoing the p clips that hold it on to the sump aswell,
gap i dont know as ive never changed one, but i think they could be a set gap im unsure
jonfoc
16
Sep 11, 2018 05:35 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
