will cossie brakes fit under 15" alloys...
im upgrading my brakes to cosworth ones, just wonderd if there going to fit under series 2 alloys?
what size discs are cosworth ones?
forgot to ask, obviously there going to be alot better than the standard brakes (1.3 mk4) but how much better?
reckon there going to be able to stop a stripped out mk4 pretti well?
i was going to go for rs turbo brakes but i thought i my aswell go for cossie ones...
Ive fitted 2WD discs and 4X4 calipers on my Series 1, that standard S1 rims just fit, there is fooook all room between the caliper and wheel weight.
Carnt coment on how well they work though.......... Ive never driven it!
yes mate.Had them on my s1,now got them on my fez. There was a massive difference between them and the standars rst items.look ia it this way,if they haul in a cossie they are gonna stop your motor as when its stripped out,it'll weigh almost half a cossie.get some grooved discs and some uprated pads and you'll be laughing
cheers for that mate...
if theres that much of a difference over standard rs items...then cant wait to see the difference over standard 1.3 brakes!
Have never driven one with standard brakes on - but the cossie ones are good for me.
We even put standard non-grooved/drilled cheapy cheap discs on temporarily to replace branded grooved items and they have been fine, even on track lol
well i picked up some 2night off my mate with good condtion discs and half worn pads..
il be keeping the standard discs as there fine, but im thinking about changing the pads, which ones should i look at buying? much difference with changing to non standard pads?
Project Money Pit
the one to do is ST170 discs and mondeo mk3 / focus mk2 / mk1 st70 calipers.. min wheels 16 tohugh, breaking power is immense
its best to upgrade to a 3i/rst mastercylinder as your pedal may not feel so great with the the 1.3 one
2wd Cossie 4 pots will NOT fit under standard S2 wheels.
NO WAY
NOT EVER
No matter how much you grind out the back of the spokes/legs.
Thanks
Jake
PS- I tried it so I know.
NO WAY
NOT EVER
Thanks
Jake
yer there 4x4 calipers and 2wd discs.
my mate had them under his 15" comps so hopefully they will go under 15" s2 alloys...
i didnt realy want to spend much to be honest as its like a budget build, but had the whole cossie front brake setup ready to fit for 60quid...realy cant grumble with that!
do i need to drill the hubs out to 12mm? he did but that was on a ka....
standard
![](http://i31.photobucket.com/albums/c392/David-Holmes/June%202007/PICT0001Medium.jpg)
Cossie 2WD discs and 4x4 Calipers.
![](http://i31.photobucket.com/albums/c392/David-Holmes/June%202007/PICT0066Medium.jpg)
fits fine with standard 15" RS Turbo alloys.
all you need is a few 1mm washers to space the calipers out.
nice one ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
much difference over the standard rst brakes?
did you have to drill the hub out to 12mm? (mate said he had to but that was on a ka)
yeh much better over standard brakes. but then i did upgrade the brake fluid, lines and pads all at the same time.
no drilling required. all you need is the washers and it just bolts up.
track.focus'd
12-08-2015 05:53 PM
Red_bull
09-08-2015 08:34 AM
