ally tig welders in here !
Old 24-02-2008 | 08:13 PM
markk's Avatar
markk
Default ally tig welders in here !
As some of you know i wanted to teach myself how to TIG ally, so i bought a cheap tig set a while ago, and have just got round to having a go, now heres where hopefully someone might help,
have alook at the pics
now this material is 6mm dural, i started by just running a bead on the material to see how it pooled when welded, added a bit of rod etc and changed a few of the many settings on the plant
now i decided to join two pieces together, and heres where i have a problem, i know it will be something simple, i just dont know what,
after the peice has been welded the material goes pitted like and then after a few seconds shows a black 'crack' line down the middle and fractures why is this ?
also how much gas pressure should i be using ?
one ive got this sorted i can weld these to my bike frame
Old 24-02-2008 | 08:21 PM
PAUL V's Avatar
PAUL V
That plate is no where clean enough, you need a stanless steel wire brush and only use it on alloy, also try and pre heat the area. have you a setting for post flow of the gas ? IE after you have laid your weld down you keep the torch close to the work pice and flood it with gas. You are useing pure Argon gas and not a argon mix ?
Old 24-02-2008 | 08:24 PM
ECU Monitor Enthusiast
I am no expert but of the two people I have observed when doing this type of
welding, they use a gas propane flame to heat up all parts before welding.
This is done so that all pieces cool down together at a similar rate reducing the chance of cracking while the weld is still weak when hot.
Old 24-02-2008 | 08:25 PM
markk's Avatar
markk
hi, yes i have post flow and is set for about 5 seconds to which i kept the torch at the end of the weld till it stopped, ok needs to be cleaner then, and a stainless brush just for the job, taken on board !
Old 24-02-2008 | 08:31 PM
Ollie.'s Avatar
Ollie.
Markk andy gallacher is your man to teach you that!
Old 24-02-2008 | 08:35 PM
markk's Avatar
markk
i know hes very good at it, just a bit to far to go for a few lessons !
ive been up there a couple of times now, the next time i go up will be to collect my car hopefully, maybe i will ask him then
Old 24-02-2008 | 09:42 PM
Fiecos Dan's Avatar
Fiecos Dan
As above, prep work, pre heat will aid you alot.
What plant are you using?
are you using the pedal to sloop down the amps as you are going?
Old 24-02-2008 | 10:05 PM
markk's Avatar
markk
its a 200 amp chinese special only single phase and yes about the pedal
Old 24-02-2008 | 10:39 PM
leecavturbo's Avatar
leecavturbo
looks good initially mark,
heard that lots of times that your
stainless wire brush should only ever
touch ally (and clean ally) i.e use another for
buffing off dirt/corrosion then use the stainless
brush prior to welding.
keep us posted.
Old 25-02-2008 | 07:07 AM
andrewg's Avatar
andrewg
6mm is a tad heavy for 200 amp chinky my 200 amp fronius cost near 4k and it would struggle welding 3mm all day thou you can weld heavier for a short time
Old 25-02-2008 | 03:17 PM
GARETH T's Avatar
GARETH T
200 amps at what duty?
use acetone to clean your work and the rods!
ill get that book to you when i get 5, it does explain it all
Old 25-02-2008 | 06:04 PM
markk's Avatar
markk
but why would it crack in the middle andy ?
Old 25-02-2008 | 06:05 PM
markk's Avatar
markk
hmmm ill have to have a look at the spec sheet to find this maybe ?
Old 25-02-2008 | 06:33 PM
crazycage's Avatar
crazycage
theres not enough weld on and you never chamfered the edges of the plate
Old 25-02-2008 | 06:43 PM
glancy2081's Avatar
glancy2081
how much was the welder you bought and does it weld good with mild and stainless steel
Old 25-02-2008 | 09:12 PM
markk's Avatar
markk
this is the plant i bought
http://cgi.ebay.co.uk/AC-DC-TIG-WELD...QQcmdZViewItem
and welds steel/stainless very nicely
Old 25-02-2008 | 09:14 PM
glancy2081's Avatar
glancy2081
seems to good to be true too
Old 25-02-2008 | 09:17 PM
markk's Avatar
markk
80% duty according to the instructions mate
mk22door
49
26-03-2022 07:15 AM
Brian
11-09-2015 08:06 AM
CrOwSoN15
10-09-2015 07:33 PM
IanC
11
08-09-2015 08:38 PM
Stavros
14-02-2005 03:30 PM
Quick Reply: ally tig welders in here !
