How safe are Puncture repairs........
#43
that there is a major fault with the side wall and you could of takin it back to the manufactors of the tyre and got a new one, providing they found what caused the issue
#49
As a rule of thumb, the speed rating is reduced. So, a V-Rated tyre becomes an H-Rated tyre. There is only a certain area of the tyre that can be repaired too.
We have lost 2 tyres on our 1.4 Clio this year (only fitted in December), had screws in them and I replaced both. Wasn't keen on the idea of repairing, even on a 1.4 Clio!!
lol, thats like saying as a rule of thumb once the tyre has been repaired you can only brake at 70% of what you normally would. Im sure braking from high speeds puts far more strain/pressure on any tyre than accelerating to the high speed does. Like has been said how is joe suppose to know that the v rated tyre on his new car has been repaired? Im sure it will become obvious that his wheel nuts were loose!
#50
They are allowed to and do repair REMOULDED jumbo jet aircraft tyres, must be because it is unsafe ?
Tyres sealed with ULTRASEAL, having had nails screws etc removed, have been used extensively in testing and evaluation over 100mph, track days, the lot.
I have only ever had two tyre problems and they were GOODYEAR EAGLE F1 GSD3 both times, developing sidewall bulges.
#51
#52
Guys...
You should know what goes on in the factory when they make the tyres, to rectify build faults you wouldn't be worrying about a decent plug repair..
cossirob
16-09-2015 07:39 PM
