which diff?
Old Oct 17, 2004 | 07:24 PM
cossie550+'s Avatar
cossie550+
Default which diff?
whats the best diff to get for a 2wd running between 550 and 600 brake without changing the rear beam to fit a jag unit? seen a gripper diff and a quaifeatb for good money, but which is the better option? cheers
Old Oct 17, 2004 | 07:37 PM
Kevin Sharp's Avatar
Kevin Sharp
A 9" diff is your only reliable option then
Old Oct 17, 2004 | 07:39 PM
RANJ's Avatar
RANJ
as per kevin the 9"
Old Oct 17, 2004 | 07:49 PM
cossie550+'s Avatar
cossie550+
thanks where and how much? cheers
Old Oct 17, 2004 | 07:50 PM
DazC's Avatar
DazC
Rare as fooking hens teeth and a few K's...
Old Oct 17, 2004 | 07:54 PM
Kevin Sharp
what ratio are you after? the 4.4,s are the most common and cheapest....usually Ł1500-2k depending on use...2k should be as new if not new
Old Oct 17, 2004 | 08:01 PM
cossie550+'s Avatar
cossie550+
thats not bad, tbh diffs and ratio's are a bit new to me but when my new engine goes in i want something that will cope with the poweralthough i wont be doing many standing launches, just out of curiosity what is wrong with a gripper diff ?
Old Oct 17, 2004 | 08:06 PM
Kevin Sharp
nothing wrong witha gripper, it the strength of the standard 7.5"crownweel and pinion that will be a problem with the power you are going to run
if you are looking for a 3.6 or3.8 9" diff expect to pay quite a bit more....
Old Oct 17, 2004 | 08:10 PM
cossie550+'s Avatar
cossie550+
right, ok thanks for you help mate will have to find out more and learn a bit about different ratios before splashing the hard earned
Old Oct 17, 2004 | 08:12 PM
Kevin Sharp
3.6 is the standard ratio if that helps
Old Oct 17, 2004 | 08:22 PM
RANJ's Avatar
RANJ
3.6 ratio 9" rear diff Ł3300
Old Oct 18, 2004 | 12:44 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
to be honest why fuck about when you can get a jag diff AND a Zoo beam for a few near enough the same money? get on the blower to them mate and make the car handle at the same time as making your diff unbreakable
Old Oct 18, 2004 | 11:25 AM
Can recommend this solution, dont forget Prop & Driveshafts as these can break .
Old Oct 18, 2004 | 05:44 PM
cossie550+'s Avatar
cossie550+
was thinking that mate cheers
Old Oct 19, 2004 | 12:00 AM
CozzyBrom's Avatar
CozzyBrom
this is a cheaper and proven product thanks to rod 750 bhp on slicks of the line
Old Oct 19, 2004 | 12:08 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
Default zoo beam
so how much does the zoo beam cost with all parts? would this be compatable with 4x4
Old Oct 19, 2004 | 09:18 AM
CozzyBrom's Avatar
CozzyBrom
it works out around Ł2600 with new prop,shafts,beam,recon uprated diff,fitting and setting up
Old Oct 19, 2004 | 10:15 PM
Lloyd's Avatar
Lloyd
ok thanks brom,but could it be used in a 4x4?
Old Oct 19, 2004 | 11:18 PM
CozzyBrom's Avatar
CozzyBrom
we currently trying to get cwp mate to suit so will be avalible the other way of doing it is on tyre sizes
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
