focus rs problem....
Old Feb 9, 2008 | 07:52 PM
focuschivvy's Avatar
focuschivvy
Default focus rs problem....
my car has suddenly started over boosting like a bitch and cuts out EVERY time it idle's?
i noticed summat was up when it started wheelspinning when it came onto boost in 4th
ive got a bailey dv26 dump valve on it (yes yes i know there shit and sometimes cause the car to cut out, and its coming off very soon )....but surely it shouldnt cause it to overboost
cheers, andy
Old Feb 9, 2008 | 09:30 PM
focuschivvy
anybody
Old Feb 9, 2008 | 10:32 PM
pani_k's Avatar
pani_k
PassionFORD Member
just a stab in the dark might be a sticky actuator causing overboost.
Don't know how this could relate to not wanting to idle. Probably should get it on a scanner mate be bound to throw something up
Old Feb 9, 2008 | 10:39 PM
MK5RST's Avatar
MK5RST
check the vacuum pipe that goes from the actuator/boost controller for any holes or maybe its off completely, this would cause unmetered air to enter your inlet and cause it to cut out on idle and overboost
Old Feb 9, 2008 | 10:53 PM
stroker762's Avatar
stroker762
Default Re: focus rs problem....
cheers, andy
I had a problem with the idle when I used the air conditioning! The engine would die when I stopped, or at traffic lights etc... My problem was software in the engine man comp. I just had to upload Bluefin, & it was all sorted. Try something the same or similar mate. Worth a go! Worked for me.
Old Feb 9, 2008 | 10:55 PM
pani_k's Avatar
pani_k
PassionFORD Member
i was going to suggest pipework but I thought that would be more for a boost leak than an overboost
Old Feb 10, 2008 | 02:41 AM
biglee's Avatar
biglee
Audio specialist
crap ford clips on the hose to control your actuator probably fell off and you now have no boost pressure to your actuator to open the waste gate hence causing a serious over-boost.
Old Feb 10, 2008 | 08:33 AM
Kev.H's Avatar
Kev.H
its its mega boosting it should go into limp mode if its still using the standard boost solenoid...
Old Feb 10, 2008 | 10:14 AM
focuschivvy
off completely cheers people for the replies!
Old Feb 10, 2008 | 10:25 AM
MK5RST's Avatar
MK5RST
make sure you get some little clips and secure them all
Old Feb 10, 2008 | 10:31 AM
focuschivvy
will do just ordered me a new pipe and ill bug them for a few clips
cheers mate
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
