any tips on how to rotate a siezed on exhaust housing?
ive been trying to rotate my exhaust housing but am not having any luck with it, ive loosened all the bolts and tried shocking it with a plasic faced hammer anyone got anyo good methods? cheers guys
tap it away fron the turbo core and also tap it left to right to brake it free and make sure once you do go to tighten the bolts up keep spining the turbo wheel as you do up the bolts stops the blades getting bent as some times carbon dosnt allow the housing to sit flush and the casing totch the wheel
Originally Posted by JTECHSAFF
on mine i used the bolts to push it off as they touched the core,so i evenly wound them out and it fell off
it works,take them steady and even, its more a case of pushing it square than anything...it will fall of this way mate...good times ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
