standerd 2wd saph map sensor were is it located
Old 15-10-2004, 10:46 PM
yogi
yogi's Avatar
Default standerd 2wd saph map sensor were is it located
were is the map sensor located is it located on the iner wing on passenger side as does the pipe run to here
Old 15-10-2004, 11:26 PM
yogi
yogi's Avatar
some one must no were a map sensor is located im just double checking that the pipe goes from there to the pic above
Old 15-10-2004, 11:57 PM
JBcos
JBcos's Avatar
map sensor is on passenger side inner wing
Old 16-10-2004, 12:08 AM
SPADGE
SPADGE's Avatar
Yep just beneath the header tank on the passenger side inner wing
The pipe can indeed go where you have arrowed
Old 16-10-2004, 07:28 AM
yogi
yogi's Avatar
well ive got no pipe going to my map sensor will this be a cause why it is over fueling????????? i hope so but the bit were the pipe goes onto the map sensor has broken away but myne is not facing down like yours spadge its just sitting flush on the inner wing above the header tank cheers for the pic tho
Old 16-10-2004, 03:00 PM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Thats your problem then, it will be overfuelling badly. You need a new one
manuel boeckx
13
03-10-2015 02:29 PM
mint_s2
02-09-2015 08:58 AM
Anutternutter
24
31-08-2015 01:24 PM
Tim Wharton
30-08-2015 05:46 PM
costina
18
25-08-2015 06:02 PM
Quick Reply: standerd 2wd saph map sensor were is it located
