Tips for Cleaning Block face
After removing a headgasket.
is just a blade suitable?
Or something else.
Same goes for the head, but head looks spotless, seems the block had all the furry gasket shit stick to it.
Or something else.
brand new stanley blade, keep it at a shallow angle though, dont wanna score anything.
and put grease round the edges of the pistons to catch any shite from going down between piston and bore before you start.
Originally Posted by xr-stu
i would never use wire wool on a block face either tbh
the ammount of strands that will end up down the bore cant be healthy....
Guest
Posts: n/a
Originally Posted by JTECHSAFF
i would never refit a head,nomatter how good it looks without either a skim,or at least get it checked for trueness,
just wot i told the boy
and : dont use brake cleaner to get that gasket off, you will end up with it down the coolant passages and in the bores / sump. u use a blade in a flat angle and some fine sanding paper to make a perfect finish.
and then get an ARP kit to put it back together and a decent gasket.
u do know ur electrics, but now listen to us
except for the ARP's
I use a milled flat bar, 2" square, of metal wrapped in knackered 1000 grade(wet and dry), works a treat, I do grease the bores first though, afterturning engine so that they are all mid way down.
I just use engine oil on the paper whne I do it.
As to head just accurately check for flatness.
I just use a blade at a shallow angle, stanley blades are ok, but if you can get an old big industrial hacksaw blade (ones that are a lot wider than normal) and then sharpen one end of it, that makes for a great quality scraper for no money that is a LOT easy to use than trying to piss about with a stanley blade as you have 6" of it to hold onto.
i've already cleaned the face with a long stanley blade (about 4" long)
seemed to do the job with a bit of WD40, i blocked up all the oil galleries before i started and tried to get as little neat the pistons or bores, cleaned those up afterwards, is there anyway to clean down the side of the piston down to the 1st ring?
Is a stanley black all that is needed for cleaning?
I use ONLY the blade, sod using sandpaper that falls apart in use and puts rough sand down your bores or oil ways etc.
Im not aware of any reliable way of cleaning down the side of a piston while its in the bore.
If you want it PROPERLY clean and flat, then take it out and get the block skimmed, anything else is not going to get as good results.
If you arent goign to take it out and strip it then I reckon stick to the blade cause if anything goes down your oil ways or bores etc, you dont have a way of getting it out again without removing the block and stripping it, and if you are going to do that then you may as well skim it!
should be fine as it is then, will just clean the bolt holes and double clean everything again before refitting.
fuck taking the engine to bits for a skim. Bottom end isnt going into bits, end of story.
In your position, I would just use a blade and accept that as good enough.
if you apply grease around the bore/piston gap at TDC and do it a bit at a time with the blade, turn the bottom end over to lower the piton and all the shit should stick to the grease, so simply wipe it off and degrease when done
do each part of the block like that and it should be ok
timsrs
22
Sep 24, 2015 08:14 PM
Si B
Sep 12, 2015 06:49 AM
