vauxhall nova wont start
my mams nova wont start.its a 1.2 k reg 4 speed.
when i turn the key i only get the hand brake light and thats it.
we used to get eng managment light and battery before it broke, but now nothing not even a click.
it hasnt been moved for about a month so my step dad jumped it, drove for a few miles,then when he got back in it, nothing
cheers
p.s i checked starter and battery all fine
cheers
3dr Cosworth owner
Typical vauxhal problem sometimes. i reckon your battery to body earth has rotted out or broken. We had to do it on my sisters nova then her astra or the gearbox earth
forgot to mention everything works,lights, fuel gauge,horn etc but when you turn key absolutly nothing,not even a click
p.s car only has 49k on and is mint condition
It wont start at all if the engine management light is not on. Also no battery light indicates a possible fault with the charging system. Id definately check the earths out first, give them all a good clean up even if they look ok.
When you say you had the lights before it "broke" do you mean before this non starting incident or has it had something else fixed and now it wont start?
just been out and tried to fire it up. all lights light up but now it was clicking so i take it the battery must be shagged
Check to see if you get all the lights when you connect it to another battery/car, if its fine, then obviously its the battery thats knackered. If not, it certainly sounds like a bad earth somewhere, or certainly some bad wiring.
DixieTheKid
11
06-06-2020 11:20 AM
TPM961
15-01-2018 10:50 AM
