any idear what this turbo is worth
15-10-2004, 05:38 PM
RS in the blood
15-10-2004, 05:41 PM
Doesnt look like it has a internal wastgate so would need to fit external jobbie
15-10-2004, 05:43 PM
RS in the blood
no it has got a twin internal wastegate
Rhys , look again
is it off a derv?
15-10-2004, 05:44 PM
RS in the blood
its ment to be a GT 35 but i know its not
looks like one of those gt43 type things,
It has an internal wastegate Rhys but looks different to normal cossie turbo ones! I have no idea what its off but it won't fit a cossie without work.
Opps sorry, shouldnt be answer thigns while on the phone as i cant do two things at once
I dunno, but Winnie the Pooh looks confused too
15-10-2004, 05:45 PM
RS in the blood
this is the spec of the turbo
Turbo Specifications:
Cold Side:
GT30R 56 Trim Compressor Wheel -2.243 in. (57mm), Inducer, 3.000 in. (76mm) Major
0.65 A/R Compressor Housing
4 in. Inlet and 2.5 in. Outlet
Hot Side:
GT37 77 Trim Turbine Wheel- 2.866 in. (73mm) Major, 2.520 in. (64mm) Exducer
0.89 A/R Turbine Housing w/Tangential Divided Scroll
Standard T4 Inlet Flange, 3.5 in. V-Band Outlet
Dual Valve Internal Wastegate with Actuator.
Bearing Section:
Oil Lubricated and Cooled
15-10-2004, 05:46 PM
Quote:
hes winking at me the little gay slut
15-10-2004, 05:47 PM
How would u bolt the down pipe onto the turbo?
RS in the blood
any idear whats its worth??? anyone??
15-10-2004, 05:49 PM
Quote:
A packet of refreshers and a curly wurly i would say
15-10-2004, 05:52 PM
RS in the blood
i take its not worth alot then?? its bran new, never been used
15-10-2004, 06:00 PM
Jeebus
If you can find out what car it was originally meant for then it would probably be worth quite a lot!
15-10-2004, 06:04 PM
RS in the blood
dont know, was told it was for a cozzie, skyline, supra etc etc
Matt Baxter
16-09-2015 08:30 PM
mrknifey
30-08-2015 11:48 AM
Harryh24
23
24-08-2015 09:07 AM
stickyslick
14
10-08-2015 06:27 PM
gordyshreds
20
10-08-2015 02:59 PM
