engine management light?
Old Oct 15, 2004 | 09:48 AM
steve rs's Avatar
steve rs
Default engine management light?
my mate filled up his 3 door this morning then when he drove out of
the petrol station his engine managment light came on. does anyone
know why it would come on?
Old Oct 15, 2004 | 11:33 AM
Matt's Avatar
Matt
engine sensor out of voltage range
pull up with ign still on/engine running
remove ecu cover
locate the 5 pin multiplug with the rubber cap a few inches down the loom
remove cap
hold the plug so it has 2 pins (holes) either side and 1 in middle at top
bridge the bottom left and bottom right pins with a bit of wire and watch the management light
it flashes in a specific sequence for each error code
Old Oct 15, 2004 | 12:04 PM
steve rs's Avatar
steve rs
ok cheers ill get him to try this
Old Oct 15, 2004 | 12:08 PM
My old 3 door used to do this a fair bit.It seemed stu found a reason somthing about the old ecu and getting engine manigment light on , the posts here somewhere.
Old Oct 15, 2004 | 12:54 PM
GARETH T's Avatar
GARETH T
something to do with stage one chips and running more boost than standard isnt it?
Old Oct 15, 2004 | 04:43 PM
Matt's Avatar
Matt
yes, map sensor out of range.... a good old 1-3 lol
sorry about size of pics, useful info tho
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Old ford
Jul 31, 2015 06:50 AM
