keeps cutting out.....HELP....
saff is working!!!...atm
well i didn't make it to the R/R day at nobles cos the car kept breaking down............BASTARD.........diagnose this.....driving along and the rev counter starts jumping up n down and the power dies....it seems like it's running on 3 cylinders and it cuts out.......u can bump start it in gear but it just gets worse and u have to pull over....it dies......it will start back up and repeat the whole thing again.....if u let it cool/leave it it will be fine for another 30 mile or so.....nothing seems HOT under the bonett and the temp guage if fine....................the car only does this on motoway journeys so it's a cunt to find/fix and as an everyday car to and from work it's fine (10mile each way)............i've got a few ideas/things to check but any advise would be nice......cheers Pete.....
You not having much luck lately........
i had same prob on a golf and it turned out to be the fuel filter...after changing everything else....
must have been full of shit and when driving it just got blocked up with shit and lost fuel pressure then cut out and if i left it the thing would start back up and run no problem for another 20mins then do it again...
Hope this helps
Hope this helps
hopefully...............took the water cooling off the turbo,runs a lot better now.....but still think h/g has gone...................
Originally Posted by pete mcrash
deffo think this is electrical.............
Could also be an ign amp,failing when it gets hot...
Team HOTHOT!
My money is on the crank position sensor and or associated wiring - Slowpoke had exactly the same problem with exactly the same symptoms, worked out that it was the white block plug that the pins had vibrated loose inside and wern't making full contact, so when the engine was revved, the pins vibrated and lost contact
Originally Posted by lawnsy
na it would not run propperly ya fueling would be all over......does it smell rich?......
Also out of daftness mate check your charging voltage of the car when running, just out of interest.
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
cossirob
16-09-2015 07:39 PM
