Is Autronic the way forward??
#201
**** BLATENT PLUG ****
SECS S8 does NOT require a new wiring loom and plugs into existing weber L1,L6,L8 and P8 without
mods (unless you want extra features)
EEC4 version (coming soon) plugs into existing FRST and COS-EEC4 looms.
#205
Originally Posted by Billabong
nope, L8 has lambda version and non-lambda version - main difference (loom wise) is the different TPS.
#206
Generally speaking most aftermarket ECU's all do the same thing IMO.
Fine adjustment of fuel and spark.
I recently looked at all the ECU's out there on the market for my car and decided to go with the latest MBE ECU.
Used Pectel T2 in the past and it was very over rated and the spec was very poor for the money.
Looked at Autronic but it did not have the functions I required. I am sure it works fine but the software looked a bit hard to get used to for me also.
It also required extra drivers to run coil on plug, (£500) extra if I remember right.
The MBE ECU had the ignition drivers built in as standard and all for £750 + VAT.
The latest MBE 970 ECU on the market was developed for the TVR Speed 12 the circuit board design has had 100's of 1000's of pounds of development work done to it making it one of the most advanced designs on the market.
MBE do not sell as much to the aftermarket as most of there work comes from the large car manufactures. Good thing is that they use the research and development from these large contracts to improve the small amount of aftermarket ECU's they sell
Some of software is also joint developed by some of the major touring car / GT teams including the Honda factory team for the injector splitmap set up for upto 18 injectors.
Enough said.
The new MBE ECU that is currently in development sounds mega trick.
It measures suspension travel and steering position to calculate launch and traction control too.
If I remember right it does loads more stuff too but I couldn't get my head round it.
IMO Highly recomended.
Can also be used similar to the Autotune setup on Autronic
Enough said.
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
#207
Originally Posted by RANJ
simon would u recommend a new loom for some one who is thinking of spending 10k a new fresh engine
The loom only needs to be replaced if faulty or is suspected faulty.
Obviously new parts are always a good idea.
I supply ecu's NOT engine packages.
#208
L8 was used on 4x4's prior to cat being required (and therefore lambda sensor) and also on the later cat equipped 4x4's. I think I misunderstood your question slightly, but believe the non cat L8 can be converted to run lambda control, but guess the earlier loom would need the extra wiring for the sensor.
I.E. ford used two versions of the L8 ECU on 4x4 Sapph's.
#210
i wana change the management in my 3dr that's all, and i wana know which is the best all rounder, the one i can get the most out of
#211
EsCos loom is slightly different to the late Sapph one I believe. P8 (EsCos) is the 'best' (out of L1, L6, L8, P8) in terms of advances made, memory etc. but plenty of big power cars running L8. You could run L8 on your loom after adjusting the loom wiring that goes to the TPS (swap outer two wires) AND by fitting the 4x4 PF09 TPS.
#212
Originally Posted by SECS
sunny, Your post (up a few now) started out being a genuine well balanced
note and then you sum it up by saying...
This is why I dubbed you a "madette". Just had to get another ozzy "plug" in.
I DO have respect for Mark/MAD and Autronic for that matter as I have said above
on this thread earlier on but your opinion is blatently "everything but autronic is cr*p"
hence my reply that you have taken offence to !
And as a matter of fact, my business is doing well despite your efforts to bring it down !![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
.....New Autronic SM4 is out very soon and I will be checking it out fully and hopefully using that for my new engine. ....
Lets make this a tad simple.
1) In the post in question I say "Pectel T6 is just as good as Autronic SM2" how does that makes it look as if I am giving out plugs for Autronic / MAD and I am saying everything but Autronic is cr*p?
READ, engadge brain then post.
2) The fact that I share what ECU I am using is also a plug for MAD? Get real, everyone on here has commented on what ecu's they are or might be using. You have no point.
3) What your business does or how well it does really doesn't bother me...no seriously it doesn't bother me. I have my own buisness and with the greatest respect to be honest that is the only business that I really care about at the moment. Your comment about me trying to bring your business down is just the funniest thing I have heard all day....I conclusively come to the conclusion with you making all these comments about anyone with a non SECS ecu alledgely saying everything else but their managment system is crap and me trying to bring your business down....to me means one word paraniod!
You have a system, it has proven to work. Respect others in the community around you instead of pissing them off with all of these pathetic comments resulting in tuner warfar. Be sucessful and respect the environment around you instead of acting paraniod just because someone posted an ecu related comment and it didn't consist of bigging SECS up. Despite what ever you think (which I can assure you is totally wrong) I wish everyone (inc you...well this probably depends alot on your response to this post) the very best of luck on here with their businesses and cars (what ever ecu's they're are controlled by).
Off to catch my 3 hours of sleep before I start my 12hr shift.....otherwise I may well be bring my own business down.
Thanks - Sunny.
#213
PassionBMW.com Member
In answer to the original question which I seemed to have missed
I dont think so, I think ANY decent aftermarket management system is the way forward and will open up a lot of possibilities for the future! Regardless of brand!.
Ive had enough of this post.
Signing Out
Signing Out
#214
Take some advice from someone that has been there, do your research and make sure that what you are buying will work and do everything as per your requirment instead of taking someone elses word for it. I have always been convinced when I have seen someone elses results with this in mind as you can't go wrong.
Thanks - Sunny.
#215
Nice pop YUM, but you aint winding me up.....
Some people after you do some proper posts...
Right regarding looms...
It really depends on life of car rather than the age.
I have tested tiff's loom and it was bang on voltage, tested marco's pectel and his had a bigger voltage drop accross it and more resistance in the earthing circuit.
So tiff's 3door would not need a new loom as far as the management is concerned, but he does need one ideally cause some cowboys have fitted an immobiliser on the piss.
My standard 4x4 saff loom is perfect and i get 13.9 to 14.1 volts all over it, inc to the fuel pumps, so why do i need a new one ?
Matt's 3door was foooked tho, had a 2v voltage drop and has done not much more work than tiff's as far as i am aware.
#218
sunny, You need to chill mate. My "madette" comment is friendly banter
and if you actually read mine and other posts you will see there is no bad feeling
or insults being thrown - apart from your bad attitude towards me.
#219
Originally Posted by Bosch Man
I cant beleive your still dissing Mark
...Berleive me he knows more than MOST...i should knowas he hasbeen teaching ME...so Gus before you say even "ima racing can map SECS" think again...Mark has REALLY helped aswell as Karl......Dingy your gripe is with Ahmed NOT MAD...so stop being childish ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
This i spoke to AHMED and he is the pectel man as most pepole know from rally car history
GESS WHAT I GET THE SECs S8 ECU NEXT WEEK AND AHMED HAS AGREED TO MAP IT
I think mark has let the cosworth pepole down as we built up his name by not mapping the car that gave him the Reputation unless we spend more money on his ECU
AHMED will map mine as i said on SECs S8 ECU and i feel that he is more worthy of my bussiness as he is showing that he WILL PUT HISELF OUT FOR THE ONE'S THAT MADE HIM (OUTSIDE THE RALLY NEWORK)
But that it my own view and the root that AHMED has agreed to help me with
THANKS AHMED AND SECs SIMON
#220
RS500/104,
#221
It could also be bollox... I don't remember mark ever slagging of SECS or saying he wouldn't work with it
I reckon if one of marks existing customers couldn't afford an Autronic and bought a SECS ecu he would map it to help them out.
#222
Well mark helped me!...on S8....he never tried to sell my autronic either as he knew i was a tight arse
....On my understanding he can only deal or wants to deal with autronic now as he is a dealer......
#223
Did Someone Mention TUV
I reckon if one of marks existing customers couldn't afford an Autronic and bought a SECS ecu he would map it to help them out. ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
#224
Mark's been building Cosworth engines for years pre-Autronic.
Seems to do pretty well out of the EVO boys, and the ads are forever running in Motorsport News aimed at the EVO rally car market, so don't just think it's all Cosworth orientated.
#225
what i am saying is MAD has moved on
but he could leave it so every one WHO WANTS TO could still use him but he has chosen map AUTRONIC or go some were else
i think its that simple
but he will do other jobs for pepole JUST NOT THE MAPPING i think we all agree that and he does help if you need it
#227
Originally Posted by Fagin
SECS or Autronic????
Mmmmmmm...... think I will stick with my ageing L6 with Super 8 board. Seems to help to deliver my required BHP.![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
#228
Porkie yes any cossie will do 200mph at Brunters with 700hp once the art is getting them to do it more than that hence the work done on Rods car this is the most important thing,
As regards not mapping Webber I have never done this and has always used Ahmed or reccomended Stu for this what has changed since then nothing now people are saying I wont work on there cars so dont go to me total load of crap it is a attemept to get work for themselfs and there Tuners.
Mark
#229
Mark, I heard a rumour you are looking to start tuning the Vauxhall Z20LET GSI
unfortunately I started it lol
#230
unfortunately I started it lol ![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Mark
#233
WHICH MEANS NOT YOU WOULD NOT MAP MY CAR ON SECs ECU
I LOOKED AT AUTRONIC AND DID NOT WANT TO RE WIRE THE CAR
BUT DID WANT THE RACING LOOM I HAVE HAD MADE
TPM961
15-01-2018 10:50 AM
