problem with gotech any help???
Old Jan 20, 2008 | 12:22 PM
picky775's Avatar
picky775
Default problem with gotech any help???
Hi all got a gotech management a couple of days age to run my fiesta turbo motor,the guy i got it off said it come off an escort cossy,spoke to jamsport and they said the ecu's are all the same appart from the maps they put in them etc,the wireing was straight forward so done that in the rain yesterday and got soaked but within an hour it was all in and sorted.Had my battery on charge for a couple of days so put that on this mornin again in the rain feckin weather!!.So tried startin the car earlier and it fired up and came to life after 5 months of sittin there,it idled very low for about 40 seconds then died again,if you try and rev it it will just cut out any ideas would be appreciated the management is gotech pro v5.Many thanx for any help.
Old Jan 20, 2008 | 01:12 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Seems like you have not got it mapped yet?, It will be running what ever map was on the Escort cosworth, which is nothing like a cvh turbo
Get it mapped, or it WILL break
Bri.
Old Jan 20, 2008 | 01:56 PM
Joe1199's Avatar
Joe1199
surely it will be running rich as anything need to take fuel out get it mapped
Old Jan 20, 2008 | 01:59 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
as above the problems the map its a wonder it even started
Old Jan 20, 2008 | 02:03 PM
GTechR's Avatar
GTechR
Ring Jamsport back up, book it in, load it on a trailer take it and get it mapped.
Old Jan 20, 2008 | 02:21 PM
picky775's Avatar
picky775
will have to put my hand in my pocket then and stop being a tite arse and get it up to jamsport then cheers for the replys peeps.
Old Jan 20, 2008 | 02:34 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
presuming youve changed some of the settings to start it? like 36-1 pick up instead of the cossy trigger and phase sensor?
Old Jan 20, 2008 | 02:56 PM
picky775's Avatar
picky775
I didnt change anything on the wireing or ecu,im running a crank sensor and coil pack i will get it off to jamsport and get it sorted.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
