what battery does a cosworth use
what amp hours battery do you need to crank a cossie from cold,14A/hours 26 or 38 recommended, whats a std item anyway? and what can I get away with using. Im using a Varley racing battery.
Do NOT use a CALCIUM battery in a cossie, the charge can go way too high for these when the battery is a bit flat, and it will kill them.
These are designed for a much gentler controlled charge as on newer cars.
Originally Posted by NUTS RuS
30 will be fine if it gets used often.
Only reason to go to a 40 is if you have hot cranking issues.
The only thing they dont like is boost charging (that will kill them) a slow low amp trickle can often bring the back to full health.
This post may interest you
https://passionford.com/forum/viewto...396184#4396184
JK12
33
26-04-2021 12:09 PM
