what does 400..
Old 14-12-2007 | 08:37 AM
R5FORD's Avatar
R5FORD
Default what does 400..
400-430 bhp at the fly wheel equate to at the wheels?? on a 2wd saph
Old 14-12-2007 | 08:40 AM
big_wig_074's Avatar
big_wig_074
2wd?obviously less losses than 4wd but there are arguments as to the amount actually lost.
ill guess that 400 youd be seeing 360 at the wheels maybe?
Old 14-12-2007 | 09:03 AM
R5FORD's Avatar
R5FORD
hmmmm so really i need around 350-360 atw in order to get 400+
Old 14-12-2007 | 09:05 AM
xr2i-carl's Avatar
xr2i-carl
at the wheels i rekon for 400, 340-350
Old 14-12-2007 | 09:06 AM
R5FORD's Avatar
R5FORD
hmm thats my next step.
aiing for 350 atw
Old 14-12-2007 | 09:27 AM
scoooby slayer's Avatar
scoooby slayer
i made 408 atw and 473 atf. a standard new fiesta st done 3000 miles ran before me and made 1 hp less than ford state atf.
Old 14-12-2007 | 09:37 AM
R5FORD's Avatar
R5FORD
thats nice power
Stavros's Avatar
Stavros
DEYTUKURJERBS
I reckon you lose about 25-35 on a FWD, between 35 and 50 bhp on a RWD car. About 80 on a 4wd.
I think any more smells a bit bullshitty to me, thats a lot of energy turned to heat.
Old 14-12-2007 | 09:47 AM
R5FORD's Avatar
R5FORD
so say around 40bhp loss??
Old 14-12-2007 | 09:52 AM
xr2i-carl's Avatar
xr2i-carl
think of it in % terms, the more power the more loss.
Given on half decent powerish manual rwd motors 50ish bhp
the saf mentioned above lost 65 bhp.
Old 14-12-2007 | 09:53 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Volkwagen Beetle. Rear Wheel Drive. 32bhp as standard. So, if RWD cars typically lose around 40-50bhp, regardless of the power they make, I presume this Beetle won't move, since it's making -8bhp at the wheels at best?
Transmission losses are proportional to power.
In answer to the question though, a RWD 200SX made 350ATW yesterday on our Dyno Dynamics RR, which was just enought to top 400 estimated Flywheel horsepower.
Old 14-12-2007 | 09:55 AM
xr2i-carl's Avatar
xr2i-carl
makes my 310bhp about accurate also, and it was the same dyno (not the same premises)
i lost bout 53bhp but its an AUTO so loses more!
Old 14-12-2007 | 09:56 AM
R5FORD's Avatar
R5FORD
so really there is no real method to working it out?? its guess work basicaly? as to many factors can cime into play
lead_foot's Avatar
lead_foot
is awesome
S13 or S14?
Spec?
GT30?
Old 14-12-2007 | 10:01 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Its NOT a flat out percantage though, same as its not a fixed number.
Things just dont work like that.
Its more of a fixed number, plus a bit of %.
Or in fact, who cares, its a SWAG (scientific wild ass guess) and its totally and utterly irrelivant to performance, and only good for showing off to other nobheads who care about a number which doesnt affect a cars performance at all.
Old 14-12-2007 | 10:03 AM
Stu @ M Developments's Avatar
PassionFords Creator
100% guess work. Read FF issue 258 for my 6 page very in depth dyno article for far more details.
Old 14-12-2007 | 10:06 AM
Christian and Beccy
#1 in Spelling Club
I think it's harsh to say it's a guess. A guess makes it sound like it probably isn't anywhere close. Dyno Dynamics have proven that they can get within a few HP of engine dyno results (if those can be taken as gospel, which in all honesty, they can't as there are as many bullshitty engine dyno's as there are chassis dyno's)
Old 14-12-2007 | 10:07 AM
R5FORD's Avatar
R5FORD
will do Stu
R5FORD's Avatar
R5FORD
im more on wheel power but i wanted to know what kind of fly wheel power i would be gettin
Old 14-12-2007 | 10:12 AM
xr2i-carl's Avatar
xr2i-carl
i think you have your answer mate
Old 14-12-2007 | 10:21 AM
Staffi's Avatar
Staffi
Mine made 376@ wheels, 442@ fly..
Old 14-12-2007 | 10:40 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the overall transmission loss from flywheel to tyre/road interface is not directly proportional to power at all.
some transmission losses maybe (like in the gearbox where more power through gears gives a proportionately higher thrust loading)
others are not, like in a rwd you may have losses due to a centre prop bearing. that does not change with power - but could change with speed
one of the biggest losses is the tyre/road, or usually worse, the tyre/roller interface (particularly if the test vehicle is strapped down with a downward force on the driven wheels). it is usually true to say that cars with more power generally have wider tyres that have a higher rolling resistance (which is part of the 'transmission loss'), so this is where the myth or assumption that more power = more losses probably comes from
in addition, cars with more power tend to run longer gearing so the wheel speeds are higher on the rolling road - again increasing the losses
quite right
i would say that based on some experimentation and experience it can be more of a 'guesstimate' than purely guesswork
Old 14-12-2007 | 10:51 AM
Lets settle on an "Educated Guestimate" shall we?
Old 14-12-2007 | 10:56 AM
foreigneRS's Avatar
foreigneRS
Testing the future
Old 14-12-2007 | 10:58 AM
lead_foot's Avatar
lead_foot
is awesome
Wheel figures are were its at.
Unless your using an engine dyno.
Old 14-12-2007 | 01:14 PM
scoooby slayer
you cant argue with stu at msd he knows his stuff and thats that. he said to me my car is a good 450 after mapping and made 470. i think some rollers are better than others run a healthy low miles standard car is my view to check if rollers are near enough. then use the same rollers as you tune i think thats the best anyone can do without taking there engine out
Old 14-12-2007 | 08:08 PM
col cos1's Avatar
col cos1
mine made 373@wheels i estimate
415-420 at crank
with more to come for 2008
Old 15-12-2007 | 12:28 AM
R5FORD's Avatar
R5FORD
i only want around 350-360 atw for now..dont want to get bored of that and have no where else to go
Old 15-12-2007 | 08:47 AM
Pump your tyres up a lot more so you have more power at the wheels!!
Old 15-12-2007 | 08:54 AM
R5FORD's Avatar
R5FORD
Old 15-12-2007 | 09:35 AM
C4llyT's Avatar
C4llyT
People tend to use percentages, but this goes out at high and low power outputs.
Most accurate way of going from ATW to Fly is add 10 and divide by 0.88
Tried and tested way, and better than just saying 10%.
342 ATW would be bang on 400 Fly with this method.
Still not 100% accurate, but cuts out the conversion guesstimate of course.
Old 15-12-2007 | 02:54 PM
foreigneRS's Avatar
foreigneRS
Testing the future
moondustka
Ford Focus RS
17
19-05-2016 07:35 AM
jundy
26-04-2013 12:39 AM
gibbo frst
03-07-2006 10:37 PM
