Brakes that change wheel offset
Resident Wrestling Legend
what are you on about?
the disc size has nothing to do with it
it's the thickness of the dics hub which means it's going to be the same across the board
the onyl reason you'll have issues is if you decided to put stoppers on that need different wheels to clear the calipers
Almost there!
if you needed a different ofset you could have the bells fabricated thicker if need be.
but you will find that most big brake suppliers make the bells to the same thickness as a standard disc, therefor not effecting ofsets etc
Guest
Posts: n/a
JoeyBoyden
04-01-2024 02:36 PM
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
