Wiring Morettes....
Wiring Morettes....
Got some Morettes for a mk5 escort, the inners are the sides? and outers main and high beam (H4).
Now from looking at just the lighs themselves it looks like the H4 connectors just wire straight into the existing socket on the car. However the inner side lights dont have this connector, I have one wire running from one side to the other into a relay then 2 wires coming out of the relay. One is brown and one is red with an inlie fuse connected. Now how do I wire these in?
Do they have to go on a seperate switch to turn them on or should I wire them into the existing sidelights?
hmmm, theres no way they can go vica versa on this as the lamps are different size and will only fit in the correct place.
How bad are they at getting them lined up correctly?
Mark RS
12-10-2015 06:01 AM
