Money no object ! Dream cossy!
after reading the money no bject dream garage thing was wondering if your numbers came up what would be the spec of your cossy!
Especialy intrested in what the tuners have 2 say!
Ive coped mike rainbirds over from the other thread 2 get it started!
1. Modification of all suspension to WRC spec, but made from Alumec instead of magnesium (due to fatigue problems, as Alumec is as stong as steel).
2. WRC active diffs and seqential FFD 6-spped gearbox.
3. 3 x T10 ECUs to run everything .
4. Dymag carbon wheels to lower unsprung weight.
5. Carbon roof to lower centre of gravity.
6. Carbon bonnet (painted white).
7. Have interior done in alcantara.
8. Car stripped to bare metal for full ground up restoration and rebuilt using replacement titanium nuts and bolts for EVERYTHING, re-wire car to remove anything unnecessary and to tidy up behind dash to achieve target weight of 1200kg and when rebuilding the car, build up and reinstall parts to achieve perfect weight distribution of 50/50 front to rear and left to right (with driver AND passenger).
9. Have floor plan re-engineered so it has a completely flat (carbon kevlar) bottom to aid down force / reduce drag.
10. WRC carbon rear wing / side skirts with camera built in and routed to screen built like rear view mirror.
11. Get Borg Warner to build me a variable vein turbo that flows 57lb of air (full boost from 2500 to 9000rpm).
12. Have a custom tall iron block cast (25mm taller), 93mm bore 82mm crank, 2225cc 1.93 rod angle and revving to 9000rpm, 600bhp and 450lb ft from 28psi.
Think that will do .
_________________
Mike Rainbird
_________________
Mike Rainbird
hadlands engine and box
active diffs
gt42r turbo
supercharger to spool it up
shell re skined with carbon
polly windows
and every thing else same as rainbird
active diffs
gt42r turbo
polly windows
DEYTUKURJERBS
Still dont think the above spec cossie would hit 200mph at brunters, and purely because of that spoiler.
Id prob run it (along with the rest of the WRC kit) as it looks badass and wouldnt be arsed about it, but seems to go against the flat bottom floor mentioned, thats all.
Escort Cosworth shell
Aluminium SBF block say 460 CI (7.5 litre)
http://www.worldcastings.com/prods_p...eyFeatures.htm
http://www.worldcastings.com/prods_p...minumBlock.htm
Skyline box
ETC
ETC
Mark
Skyline box
ETC
ETC
Mark
an rs500 with 1000 hp and the best of everything
What the fuck thats like me saying id have a 1500hp escort with f1 bits!
And not explaning how the fuck u were going 2 achive this ! hopes and dreams ?
Any1 can say the best of everthing! the idear is 2 explane what ur best of everything is!
Everything from that 760 hp Jenspeed RS200, in a 3 door shell.
(Including the BDA engine, which I know is not strictly cosworth!)
Or Rolf Klypen's 780 BHP Jenspeed 3 door.
Also I would rather have a box geared for ~ 160 and get there stupid fast than be able to do top speed. No disrespect to any top speed people, just doesn't float my boat. Midrange to be able to spank evos, porsches, astons etc does. In a 20+ year old ford.
personaly id have the blue norweigian escort cossie, i know its grey now but id get it painted blue again & leave the 850 odd bhp engine in it with every thing thats on it
DEYTUKURJERBS
And most the races ive had against REALLY fast cars often ended 160+ (clock speed) so topping out at that speed might not be a good look, esp as 750bhp+ going through the rear wheels means you prob wont have any grip till 160mph anyhow
Guest
Posts: n/a
Originally Posted by cozzfather
Thats well nice
Originally Posted by dovboy
standard saff with veyron engine
Cant see the diff lasting
Stians original escort would keep me happy
C.R.E.A.M.
need is this one, and the fella in my sig is selling it
http://www.motorsportads.co.uk/rally-cars/7684.html
ex works wrc
I think andyg is just about to build it, but would mibi go ffd box with active diffs.
Or if it had to be based on an original cossie then a escos with front spaceframed to alow fitment of ava's twinturbo set up, ohlins shocks ,ffd box ,active diffs ,carbon wrc style body work and 19" mag centerlocks with 380mm 8 pot brembos front and 355mm 6pots rear.
Caraholic
Seems a waste to have a flat floorpan etc to reduce drag but then have the WRC rear spoiler which gives the car incredible amounts of drag at very high speed?
The flat floor reduces drag AND increases down-force, so at higher speeds, it would accelerate through the air faster, as well as being more stable and pinned to the track with actual positive down force. The fact that my dream spec engine only produces 600bhp (approaching the limit of the Mountune roller barrel intake) should have indicated to you that 200mph top speed was immaterial to me (although the gearing and revs it would pull would give it the potential to do so with 150bhp more power ).
As to your comments about the rear spoiler, again as has been said, the WRC item gives more downforce AND less drag than the original . However, I believe that Martin will be the proof of the pudding with his 700+ bhp engine, as his is geared for dead on 200mph at just over 8000 revs .
My dream spec was for my own personal remit, which is a devastating track car that car be driven in (relative) comfort on the road.
Not welcome...
ex works wrc
Originally Posted by Rolls
Put me down for one of Mikes versions... - In fact, sod it, I'll have 2
Caraholic
ex works wrc
Happily retired
Don't know about a cossy but I came across this going through the links
http://www.motorsportads.co.uk/race-...cars/7418.html
Caraholic
Silly question, but why the 3 T10's? are they unreliable and you need to cary a spare?
And dont go for active diffs....modern WRC cars are now back passive....thank fook.....
I'd go for a standard small turbo Escort, remaining near to it's original power level, and have it over-engineered, so that the likelyhood of it breaking down is minimal.
It would be used as a road car so the brakes, tyres and suspension would be of a high standard and set up to compliment each other. The body of the car would be refreshed and stiffened (but not considerably so). Wiring would be renewed. Finally, a high quality ICE setup would be installed - just four good speakers and a one reasonable sub tucked away in the boot.
With that all done, reliable endless enjoyment would be mine.
