ANYONE KNOW OWT ABOUT ROVERS
depends on the year of the piece of.....british engineering.
Open up the fob, slide out the battery, press each button and slide the battery back in. Do this quite quickly.
Lock the door with the key, and stand beside the car and press the lock and unlock button one after the other, over and over and over again untill the doors unlock.
If this doesnt work within a couple of minutes, disconnect the car battery for 2 minutes, and start again.
Usually works!
Some later 400's have a security number in the hand book which you enter by turning the key in the drivers side door lock left and right according to the number.
i.e 1234 would be left,right right,left left left.. oh you get the idea!
Good Luck.
Usually works!
Good Luck.
Usually works!
Good Luck.
Usually works!
Good Luck.
Thanks
Buy a new 5a or 3a module and keyfob from the scrappers its normally the module thats fucked not the fob, My neighbour is having this problem at the min but he's lost his rag with it and buying a new car even though ive told him whats up with it
Yeah its off barley rise If you want a hand filling them in and want to come to a few drill nights and see what its all about let me know and ill sort it
Yeah pal, its retained (part time) ive just got myself a Volvo 850 T5 Estate in white but also have a 2,1zvh van but it aint practical to get to the station in 4 minutes at 3am booting it from cold
Originally Posted by dakar
Never seen van about mate.Will keep an eye out for it
It's a common problem - the system just forgets the keyfob code.. you need to get it reprogrammed in, takes about 3 minutes with the right kit. Anywhere with some half decent code reader/scanner kit will be able to do it.
Changing the 5AS immobiliser box and matching key won't help as it still will need matching to the engine ECU.
1st to 200 without NOS
rover!! ha thats what you get 4 insulting the scarborough lads,you best not bring that piece of crap onto my street or ul have neil to deal with.Well maybe
seconded
seconded
There you go Addukk or whatever its official your all rent boys as i said
what's the key fob look like?
depending on the year of the car, Rover had 2 different systems. Infra red or the 5AS.
if you've got an infrared system they are a piece of piss to de-activate, you can tell if you've got a infra red system as the interior light will have a dark piece of plastic at the end.
if its a 5AS unit you will have a 2 button keyfob which will have Lucas written on the back. let me know what you have and i'll tell you what you need to do.
if you havent got that speak to this guy
http://www.remotekey.co.uk/
or
http://www.bestofbritishrover.com/
or
Originally Posted by LHD220Turbo
have you got all the docs with the car? if so look for an eka code
