can someone tell me.... UPDATE
....where the fuel pump relay is on a mk6 escort GTI
no pump priming noise when i turn the key. tried the re set button but still nothing
Baby Cheesus
its a small brown relay in the middleish of the board, fuse no5
you may find that its the fusebox that is fooked as this happened on my escort cabby, i had to bridge out fuse 5 to the relay for a temp fix
they get dry solder joints and fook up often
if it is the box, take a pic of all the links and relays etc, then remove them all and all the plastics surrounding it, they re-solder every joint you can get the soldering iron on. i did this to mine and it was fine after
if it is the box, take a pic of all the links and relays etc, then remove them all and all the plastics surrounding it, they re-solder every joint you can get the soldering iron on. i did this to mine and it was fine after![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Put power straight from the pump wire and it wants to run?? I can hear a small clunk noise coming from inside the tank? Maybe the pump sucked something in and jammed?
update.
Dropped the tank and took the pump unit out of the top. put it to power and it sounds seized.
a mate has got a mondeo 1.8 breaking so i took the top of the tak out of that ( alot easier than the escort as there is a big enough hole under the rear seat to get to it ) and the actual pump was the same part number and size so i swapped that into where my one sits in the sender unit.
put it back in the tank and connected it up and it primed up and started...
lifted the tank back up and same thing again.. small clunk noise but no priming noise??????????
no pump priming noise when i turn the key. tried the re set button but still nothing![Top](https://passionford.com/forum/images/smilies/smile011.gif)
TPM961
15-01-2018 10:50 AM
