Hi spec..how shit
Old 22-11-2007, 06:37 PM
  #41
Nash
Cake lover!
Nash's Avatar
Originally Posted by Dan
Originally Posted by Nash
Year ago a very good friend of mine took a set of Hi-Spec brakes apart to look at them. He was shocked to find they hadnt used shanked bolts but full thread, he was even more shocked when the bolts were not even heat treated!!
I know this was then changed on all new products. My point is why did it take someone to point this out before it was changed? This should never have happened in the first place.
For this simple reason i would never use them.
Your AP 330's were on the car when you bought it wern't they?
What have you used in the past, always been an AP boy?
Yes they were Dan.
Yes only used AP's on the Saph.
I know Nick used to have standard 2wd calipers with larger discs and bells. Nick really rates this set up if you are on a budget.
Old 22-11-2007, 08:32 PM
  #42
R5FORD
R5FORD's Avatar
Originally Posted by iansoutham
A couple of things on this subject (well, the original one anyway)
The service from Hi-Spec has been lousy in recent times due mainly to the lads who have worked there. One of them has now left, and the other is out sick. If you speak to Jeff or Fiona (who is currently running the front-of-house as well as the accounts (paperwork side) then you will have no problems.
The lads are the main problem. I have a mate who got a set of 300mm 4-pots for his RS2k and was told by the lads that he had to change his 17" Ford 7-spoke softedge wheels as the Hi-Spec kit would not fit. No ifs, no buts, like it or lump it attitude. We spoke to Jeff personally who said that all you have to do is use a special bell and bracket set which moves the caliper further in, aleviating the problem. Modified parts were supplied, brakes fitted, job jobbed. If you really want a decent service, then ring on a Saturday morning when only Jeff and Fiona are there.
I got a brake upgrade kit from Fiona myself today and it was a nice, simple, easy transaction and even got discount purely by asking.
So, in simple terms,
speak to the lads = crap service, failed promises
speak to the bosses = good service, fulfilled promises
yh right Finona is just as bad..she fckud me around for a month before she told me where my callipers were
Old 22-11-2007, 09:35 PM
  #43
roop
roop's Avatar
i've used hi spec several times in the past and have had nothing but trouble with parts not fitting/bad reliability and the same with my mate,you get what you pay for and would not use hi spec again under any circumstances
Old 23-11-2007, 12:31 AM
  #44
Kelv
Almost there!
Kelv's Avatar
for those exact reasons id never use hi spec again.
i first used Geoff around 8 years ago and was apalled at his service, let alone the lack of quality of his shonky goods. anyone who has been to him since has always has similar experience - and i always say avoid them but no one listens until its to late.
his rear brake kits come with hoses that are to short (unless hes now rectified that problem), discs that crack in record time - and he will always find a way of blaming the customer.
Mike, i know your customer service is good, but to still buy goods via yourself that have come from that prick is never going to be good enough for me.
id rather lick piss off a nettle than have anything to do with Hi-Spec.
Old 23-11-2007, 01:56 AM
  #45
RWD_cossie_wil
RWD_cossie_wil's Avatar
Tim,
You can't expect their budget kits to work as well as APs . If you move up to the their better kits, which use PF discs etc, then they are still cheaper than AP, but have nigh on equal performance.
Braking is also about pads and fluid, so you have to make sure the kit is specced correctly for each application as well .
You should take a look at their Mega-monster 6 calliper - it really is a VERY well made piece of kit .
How much is a Hi-spec kit closest to 356mm x 32mm 6 pot kit all in inc VAT + deliverey then mike? ( kit for comparison would be rotors {grooved}, bells+all bolts, brackets, DS2500 pads, 6 pot callipers and braided lines) - For an Escort cosworth
Old 23-11-2007, 08:05 AM
  #46
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Wil,
The AP 6-pot (black CP5555 callipers) 356x32 kit is Ł1,865.00 (the red "budget" CP7040 is cheaper at Ł1,645.00)
The closest to that is the Mega Monster kit, which uses 360 x 32 Performance Friction discs and the pads you quote, which is Ł1,750.00 through me .
The AP 6-pot (black CP5555 callipers) 378x32 kit is Ł2,368.00 (the red "budget" CP7040 is cheaper at Ł1,938.75)
The closest to that is the Mega Monster kit, which uses 378 x 32 Performance Friction discs, which is Ł1,800.00 through me .
Old 23-11-2007, 08:23 AM
  #47
Disabled Account
Disabled Account's Avatar
Wil,
Mike,
Good info there........what sort of discount would be available to an impoverished & humble builder of loudspeakers? I should add, one that has the utmost respect for you and your fine knowledge of all things Cosworth......
Old 23-11-2007, 08:31 AM
  #48
Mike Rainbird
Caraholic
Doug,
That is already giving a 10% discount .
Old 23-11-2007, 09:17 AM
  #49
4x4
4x4's Avatar
Originally Posted by R5FORD
i think Tarox are better than Aps
hope thats a joke good sir
Old 23-11-2007, 09:32 AM
  #50
R5FORD
R5FORD's Avatar
no not really..i actully prefer tarox to ap's
Old 23-11-2007, 09:37 AM
  #51
Mike Rainbird
Caraholic
There's nowt as queer as folk .
TPM961
15-01-2018 10:50 AM
Mc5506
05-10-2015 09:57 PM
gcfcos
88
15-09-2015 03:48 PM
Ben26
27-08-2015 08:56 PM
Quick Reply: Hi spec..how shit
