MLR Rolling road today......477 bhp...Graph added.
#122
NEEDFORSPEED
thanks Mark.
rapidcossie
a bit too awesome Euan.
thanks Mark.
rapidcossie
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
#124
dingy
how is that.![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
how is that.
At all 4 wheels....
So what difference does it make if its 4wd.....cause it has more power at the wheels...
Normally 2wd make more at wheels due to less loss's etc....but at the wheels figures are at the wheels figures....so the fact mine is 2wd has no meaning on the arguement....
This just show's me how shite DD rollers are LOL and how mike r reckons they are consistant in power readings LOL....
Like i said PUB talk
#125
Cake lover!
Originally Posted by dingy
Originally Posted by Nash
dingy
mine was coughing and popping due to low petrol.
yours a lot lighter too...
i'm not arsed at all though.
see you at Dono Steve.![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
![007](https://passionford.com/forum/images/smilies/bond.gif)
You doing Daddy thrash or Retro Thrash mate?
#128
rapidcossie
suppose so.
if anyone asks i always say its round about 400 ish,think i will still stick to that.
suppose so.
Cams and fancy head and some 1000cc injectors next
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
#134
You not been dipping you wick where you shouldnt have, have you?
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
#135
dingy
still goes round corners jsut as fast dave, must be the driver eh
#142
have you got the boost graph?
Who mapped it? as fueling isn't good at all in the mid range. (top end must be the inj's maxxed out.)
#144
Sorry but there upside down.
the cars that turned up today.
a good range of cars from the MLR group
,shame a good few never turned up.
![](https://img.photobucket.com/albums/v490/davecos/18112007346.jpg)
![](https://img.photobucket.com/albums/v490/davecos/18112007348.jpg)
oh...thats the one for the wheels.
![](https://img.photobucket.com/albums/v490/davecos/18112007350.jpg)
![](https://img.photobucket.com/albums/v490/davecos/18112007345.jpg)
Let the arguing commence.
Heres my observations on the graph,
The Intake temp has over corrected this is a typical dyno dynamics action they say place the temp prob in the airfilter but this makes it correct upward, I tested this a while ago and 15c added 2.5% to the total power yours has corrected 42c
![](https://passionford.com/forum/images/smilies/wow.gif)
On the lambda reading sometimes this can be wrong if they have used a short pipe in the tail pipe and you have a small baffle tube in the back box then pulls in air which then will show lean, This could be your problem but I would get this checked,
This is not a dig just a highlight of what I have found using these rollers.
Mark
#145
Norris Motorsport
Dan, I mapped it.
Dave, you need to turn the boost down or get it back to me for a check up. The AFR is too rich midrange and leaning off quickly at top end. This indicates to me that you are running over the 3 bar map sensor threshold.
For now make sure its holding no more than around 28psi, but I'd advise another check over since you've had the turbo rebuilt.
#146
Fiecos Dan
Dan, the boost map is what you would of been looking at if you noticed the fuelling,its next to it![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
#147
Originally Posted by Karl
Dan, I mapped it.
time for a 5bar.
#151
Mark Shead
can you put that in English Mark.
Karl,
i will turn it down and get it checked over![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Karl,
But in practice this gives engines with hot air intake more power but in practice this is not the case as the temp should be corrected for cell temp not air filter temp,
Whenever I run on these RR I have the air temp probe hanging in the cell so it corrects for cell temp.
Mark
#153
Mark Shead
still 'no comprehenday Mark'
have i got 400 bhp,that will do me.![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Mark
#154
Mark Shead
Mark
#156
Originally Posted by Mark Shead
Mark Shead
Mark
no shit Mark.
i think everyone knows that is highly unlikely with my spec lol.
is 400 a lot lol.
#158
Norris Motorsport
Dave,
Seriously Dave, from mapping your car and knowing that the engine can out run the greys when running over 28psi, I think a good estimate of engine power is around 420bhp @ 28psi.
Unless its an error in the exhaust sampling, the AFR is leaning off quickly as the revs rise, indicating that you have reached the maximum duration time of the greys. As said for now turn the boost down to no higher than 28psi, as this is the maximum I was able to map the car to. Above 28psi it started to lean off after 5500rpm.
If you're interested I can simply remap the car on some 750cc injectors and a 5 bar map sensor if you want to ensure reliability at higher boost levels.
#160
Originally Posted by staffi
So, hold on then, if yours is wrong Dave, that makes the Evos all wrong aswell..
You will find the evo's have a slightly better airfilter postion and the temp wont be as high so the correction wont be, But you can see this on the graph.
Mark
