Wheel not touching hub nut with spacer on, is this bad?
Might be a really daft question but something i did not consider until i noticed it yesterday.
Basically, the ring that locates the wheel around the outside of the hub nut on your front hub, does it HAVE to go inside the wheel to provide extra support for the wheel or not?
I.e situation is that I have big brakes and 17" RL7 wheels and need to fit longer studs and spacers to clear calipers and it appears that the wheels will go on but are only supported by the suds, i.e the hub nut is too far back and does now not touch the wheel.
Might be worrying over nowt, and offset aside, just wanted piece of mind really.
If at all possible yes, how big are your spacers???
If they are about 10mm or more then you should get hubcentric versions which come with the centres that the wheel locates on!!
HTH!
HTH!
Ah thought as much....cheers, so where do I get "hubcentric" spacers from, the ones i have on are 10mm, haven't driven the car yet so ust as well....
I had no idea what hubcentric spacers were, but remembered the name when i saw the problem and thought this was maybe what i needed...![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Thanks for your help.
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
![](https://img.photobucket.com/albums/0903/Silvercossie/DSC00263.jpg)
JoeyBoyden
04-01-2024 02:36 PM
GTR_STU
28-08-2015 01:02 PM
rst-s1
23-08-2015 07:56 AM
RSMK4TURBO
19-08-2015 04:46 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
