Big Up MADevelopments
Motec Air/fuel ratio contraption has landed Just waiting for lamda to arrive from Germany...be here today Much appreciated Mark...
Hopefully ECU tommorow.....then its let the mapping commence,this venture is hopefully not going to go off with a bang
LOL...shouldnt do as i have a particualary person helping me with the base map etc...you all know who.....
Who'd have thought i would be using the greatest dancer of all time?!
Originally Posted by Bosch Man
.....Deano its better than having a brown cock thru too much anal with your boyfriends
Phil you want to check the fueling on the L8 to see if the chip has any issuses and that the car runs ok so you dont get side tracked if there is a problem somewhere.
Mark
Mark
Mark....the L8 was running fine....i had the pectel moniter thing which showed everything a ok...LOL.....I am now running brand new greens and a new sub loom.
I have fuel pressure gauge also and again everything is doin as it should IMO...LOL
Plus i already ripped the greys/ecu out
Stu i only ever had issues when using it on 8 injectors and admitted this On the stage 3 it was fine wether i set it up wrong or not!...I still had good fuel pressure due to gauge
Phil I would have done a dett test and a fueling check first then you have a base line to work from just to be safe as its the first time you will be doing this.
Mark
Mark
Phil it would give you some experiance on how the car runs on these settings on the L8 rather than start from scratch with something that is unknown,
Also if the engine has been detting its head off before not saying it has but at least this way you know rather than start on a engine that could be about to fail this would protect you and the programer from this.
Mark
Mark
Mark...the engine has only done 850miles i only just finished running it in and have done 40 miles with the boost turned up to 1.6bar!!!!......It should be very fresh
Indyrs
04-12-2022 12:39 PM
SMILER258
28-09-2015 09:04 AM
