cooler the fuel the more power it produces?any body coment?
Old 05-11-2007, 08:02 PM
  #121
Chip
*** Sierra RS Custard ***
Chip's Avatar
Originally Posted by radiant red
I think chips bang on for his entertaining and knowlegable replies, makes perfect sense to me
Cheers mate
Old 05-11-2007, 08:37 PM
  #122
dojj
Resident Wrestling Legend
dojj's Avatar
did we ever get an answer then?
or does it have not a lot of consequense to your average mondeo owning pootle to the shops sort of driver?
if everything is to the limits then i can see where the slighetest difference from what it needs to be will cause a deiscrpancy, but a near 10% loss of power just because your fuel got a bit hot is a lot of power you are losing
who's to say it's not due to some other factor? how does it react out in the real world of driving up the road?
could you not simulate some back to back tests to facilitate this sort of measurement on/off the rollers?
Old 05-11-2007, 08:42 PM
  #123
nilrem
STOP!... Carry on
nilrem's Avatar
a bit off topic i know... but am i right in thinking that diesel works better at a warmer temperature, where as fuel works better at a cooler temperature?... im fairly sure, but thouhgt i would ask...
Old 05-11-2007, 08:46 PM
  #124
Chip
Chip's Avatar
Simple answer : It gives more power, but only a very small amount, not enough to really start fabricating things for your car in the hope of gaining literally a couple of bhp at most.
Old 05-11-2007, 09:22 PM
  #125
rapidcossie
rapidcossie's Avatar
the question you need to ask is..........How hot is the fuel actually getting?
Old 05-11-2007, 09:27 PM
  #126
radiant red
radiant red's Avatar
Suppose it can only be heated around the engine bay where it passes on its flow around the system??
As mentioned on the F1 query a few weeks back, they quoted 5 or 6 bhp increase on a slight temp drop on a 800 bhp engine.
I really have no idea how hot it gets, if it was an issue surely dyno experts etc would measure the temp when mapping etc
Old 05-11-2007, 09:31 PM
  #127
rapidcossie
I know hot it was in my tank and going by chips percentage calculation it was more than 2 or 3 brake.
Old 05-11-2007, 09:35 PM
  #128
Chip
Chip's Avatar
Bear in mind what an artificial environment it was though in terms of lack of cold airflow under the tank to cool it, so the temp difference you saw (if you measured it at all?) was probably not something you would see in the real world away from the rollers.
Old 05-11-2007, 09:36 PM
  #129
radiant red
Suppose sat on a rolling road its going to heat up more than general driving, i would like to see an accurate test on this subject. Wonder if stu has any thoughts on this.
Old 05-11-2007, 09:37 PM
  #130
rapidcossie
that may be a fair point chip.
one reason we have taken no precautions against it on the car.
Old 05-11-2007, 09:39 PM
  #131
Chip
Chip's Avatar
From what I recall of your car on AVA's rollers, doesnt it have a fan that is VERY well directed into the engine bay only as well, so probably literally no cold air at all directed at the tank?
Old 05-11-2007, 09:42 PM
  #132
rapidcossie
yeah its ducted straight on the front of my car
Old 05-11-2007, 09:44 PM
  #133
Chip
Chip's Avatar
Certainly going to exagerate the temperatures reached then compared to on the road.
I think a subtle and important difference needs to be drawn on this thread between trying to avoid your fuel becoming super heated, and bothering to try and cool it below ambient
Old 05-11-2007, 09:55 PM
  #134
rapidcossie
trying to acertain how much power is actually lost is the difficult thing.
Old 05-11-2007, 09:57 PM
  #135
rapidcossie
the winning time attack subaru of power station/litchfield ran a fuel cooler.
They must have thought it was worth while..
Old 05-11-2007, 10:04 PM
  #136
dojj
dojj's Avatar
would it not be heated along the way with the pipes running some portion along the same sort of things as the exhuasts?
Old 05-11-2007, 10:29 PM
  #137
Steven_RW
Steven_RW's Avatar
First person to convert the old temp gauge on the dash for fuel tank temp is the winner
RW
Old 05-11-2007, 10:38 PM
  #138
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
RW
APMSL
Back in the day it would have been you Steve. If only you hadnt had to move the instruments to get that offensively large chargecooler system in place. The good old days.
Old 05-11-2007, 11:21 PM
  #139
Steven_RW
Steven_RW's Avatar
LOL - u know its true stu - u know its true.
I keep wondering what the M3 would be like with a muckle great big turbo...
Im sure we could get similar power to Euans car - slightly less lag due to 3.2 litres and a wicked top speed (good gearing as std and relatively good aerodynamics) (speedo would potentially read 207mph at 8000 rpm, if it went that high lol. Its purely based on a speedo /revs and multiplied up from 6th gear.)
Anyway - i think Euan was brash to comment without detailing exact circumstances and other factors.
However its the internet and who can be arsed to write every tiny detail when its potentially a massive waste of time - cos it soon drops off the first page to be replaced by posts about novas and alloys or something lol.
RW
Old 05-11-2007, 11:27 PM
  #140
Benni
Ban[B][/B]ned
Benni's Avatar
I'll second that mate, this thread was a little confusing until he added his input and cleared a few things up. Looks to me like Phil has come in and stirred things up a little as per usual.
Benni.
Old 06-11-2007, 07:05 AM
  #141
dojj
dojj's Avatar
which one is phil then
Old 06-11-2007, 07:33 AM
  #142
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Would make sense if you're running a rediculously small tank like most of the time attack cars do, as the fuel would soon heat up (going by your own findings of running the car low on fuel) .
Old 06-11-2007, 07:42 AM
  #143
Chip
Chip's Avatar
Again, this comes back to what I was saying yesterday about it being worth trying to stop your fuel getting ridiculously hot, but its not worth trying to cool it down from "normal" temps on a road car.
Old 06-11-2007, 08:08 AM
  #144
ian sibbert
ian sibbert's Avatar
Surely the volitilaty of the petrol could be at the root of the power loss, such chemical components might be lost as the temperature of the petrol increases and the fuel becomes saturated (evaporated) in the tank, with that in mind better insulation of the tank would be a more prudent approach to ensure the chemical compostion isnt spoilt.
I seem to recall petrol begining to displace at about 45'C, although I think the actual boiling point is nearer the 150'C mark.....I was also under the impression new blend fuels (super Unleaded etc) evaporated sooner than older type fuels to give better performance once at the injectors, could this in an old metal fuel tank could contribute to faster evaporation?
We always insulate fuel tanks with a decent heat sheild material to avoid heat soak from the exhaust.
Old 06-11-2007, 09:03 AM
  #145
radiant red
*We always insulate fuel tanks with a decent heat sheild material to avoid heat soak from the exhaust*.
Thought that would be more of a safety measure?
Old 06-11-2007, 09:59 AM
  #146
foreigneRS
Testing the future
foreigneRS's Avatar
without having a cooler, i would have thought that insulating the tank would be the last thing that you want to do as you will then never get rid of the heat added by the fuel pump (except by relying on the metal pipes running from front to back to do it, but for people who have replaced those with braided hose it's not going to be much good)
Old 06-11-2007, 10:43 AM
  #147
Chip
Chip's Avatar
Insulating near the exhaust however DOES make sense
Old 06-11-2007, 10:57 AM
  #148
ian sibbert
Insulating works both ways....you can insulate a building for instance to prevent the heat escaping (cold country) but you can also insulate to prevent the heat increasing the internal temperature (hot country)...
We do a lot of work on CO2 storage tanks with CO2 in saturated (liquid and gas state) and the solar heat gains on tanks with failed insulation is enormous....makes the refrigeration equipment work less effectively and for longer....
If you had an uninsulated steel tank imagine the effect on the saturated CO2....it would be into gas and evaporating in no time....pressure/temp would increase etc....insulating it prevents the majority of this happening, in conjunction with refrigeration equipment to control the temp/pressure of the vessel....
I appreciate petrol is a more stable than CO2 but the effects are similar...If you can keep the petrol at the temperature at which is was dispensed and you can control the temperature at source its less likely to need conditioning....
The absorbed power from the fuel pump imo would have little effect on the mass of fuel you had in a car......approx 700W versus 40 - 50 ltrs fuel....
Just another slant on the debate....
Old 06-11-2007, 11:10 AM
  #149
rapidcossie
My intial coment said that we noticed a power loss from heated fuel.
I didnt detail how it was heated.
You said I was talking bollocks and it would make almost zero diferance., clearly some very professional people think otherwise.
Old 06-11-2007, 11:19 AM
  #150
gingeRS
gingeRS's Avatar
we do.....but thats with diesel ....i am unsure as to the effects with petrol
though we do have corrections for fuel temperature, it is very rare for an OEM to fit fuel temperature monitoring equipment
Old 06-11-2007, 11:20 AM
  #151
rapidcossie
specially if your new twin 3" exhuast runs close to the fuel tank
Old 06-11-2007, 11:23 AM
  #152
Chip
Chip's Avatar
I wasnt picturing you being stupid enough to let the fuel get VERY hot, so I do apologise for underestimating your stupidity somewhat
Again though, your comments still had NOTHING to do with cooling fuel beyond ambient which was what the thread was about, you dont seem to be able to differentiate between the two concepts.
OF COURSE its going to lose you power if you heat the fuel so much it starts breaking down or evaporating, but that doesnt mean you can gain a similar amount of power by cooling fuel that is in a normal state.
In fact if you are dumb enough to let it get REALLY hot, you could lose 100% of your power, not just 10% as you will get to the stage the car wont even run.
Old 06-11-2007, 11:28 AM
  #153
rapidcossie
LOL @Chip back tracking
Now admits heated fuel does make a difference
Old 06-11-2007, 11:33 AM
  #154
Chip
Chip's Avatar
OF COURSE IT DOES IF YOU LET IT GET *THAT* HOT!
I was wrong in my first replies, it never occurred to me that a supposedly professional outfit like AVA would ever allow that situation to get THAT bad.
You are totally correct to pull me up on it, I shoudlnt make assumptions in my posts, like assumptions companies have a clue what they are doing when designing exhaust systems or running cars on the rolllers.
I accept the for not being thorough enough with making my reply idiotproof.
Its always the way though, you think something is idiotproof and along comes a bigger idiot.
I will be more careful in future, thanks for pulling me up on it!
Old 06-11-2007, 11:38 AM
  #155
Stavros
DEYTUKURJERBS
Stavros's Avatar
I thought you WASNT keeping on and on just to win an argument?
Dont seem like it!
Old 06-11-2007, 11:42 AM
  #156
Chip
Chip's Avatar
Dont seem like it!
Ewan brought up the subject of wether or not in my original reply I should have allowed also for VERY high fuel temps, I was just replying to him, it wasnt me that brought up that line of discussion.
Old 06-11-2007, 12:00 PM
  #157
Mark_w
Mark_w's Avatar
So it seems that euan was 100% correct in his initial statement Its great how some people can comment /offer advice on the subject without being there at the time and have never carried out such testing,only adding input from what the have read on the internet or from a book
Euan,your car seems to be well sorted
regards mark
Old 06-11-2007, 12:05 PM
  #158
Chip
Chip's Avatar
regards mark
Very good point mate.
I shouldnt have made assumptions AVA wouldnt allow the fuel temp to get ridiculously high as I never would myself, so my own experiences didnt prepare me for that scale of mistake its true.
I even commented that it was useful in diesels only cause they see temps that petrol never does, shows how wrong I was about what some people choose to do with their fuel temps!
Old 06-11-2007, 12:08 PM
  #159
Steven_RW
Steven_RW's Avatar
So - if u let fuel get to a certain temp (not sure how high) it could make 50 bhp difference on a 500 bhp engine? Did we just agree that?
All that we don't know, or more the case that only AVA know, is what temp the fuel got to when they happened to see a reduction in 50 bhp.
Is that about right?
RW
Old 06-11-2007, 12:09 PM
  #160
Chip
Chip's Avatar
PS
Seeing as we are now apparently having to be VERY idiotproof with our replies to not have fault picked in them for lack of detail, I would just like to mention (even though to me it seems obvious)
A fuel cooler wouldnt actually help in a petrol car once you have got the fuel so hot it starts to break down and elements of it evaporate etc.
Quick Reply: cooler the fuel the more power it produces?any body coment?
