rx7 problem
Old Oct 29, 2007 | 10:05 AM
abdr500's Avatar
abdr500
Default rx7 problem
a m8 of mine has bought a rx7 now the car dont start but if you keep at it it will start and run lump the bloke that he got it of rekons that thr rear apxi is gone any one now what that is or better still what is the common problem with these car for starting
Old Oct 29, 2007 | 10:32 AM
scruffythefirst's Avatar
scruffythefirst
Engine re-build time. Do it sooner rather than later as low compression causes poor starting and eventually the apex seals disintergrate and take all the rotors and housings out, meaning most of the rotor becomes scrap, not to mention metal bits taking out the turbos too.
Old Oct 29, 2007 | 10:53 AM
Mr Whippy's Avatar
Mr Whippy
Oderint dum metuant
Exactly the same thing happened to mine! And if you have tried to run it in that condition there is a 99% chance that the housing is scrap already.
Depending on where you are, Pip at WGT in cheshire is very reasonably priced for rebuilds
Old Oct 29, 2007 | 11:22 AM
Escort-Ian's Avatar
Escort-Ian
As said, dead rotor tip (apex seal) and ain't gonna be cheap! Same happened to mine...
Old Oct 29, 2007 | 11:24 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
fucking cheap compared to a rebuild on most performance cars tho!
well, obv more if its badly damage the housing...
Old Oct 29, 2007 | 12:21 PM
Escort-Ian's Avatar
Escort-Ian
Oh yeah, goes without saying! But I'm a tight arse sometimes so it was expensive to me
Old Oct 29, 2007 | 08:37 PM
abdr500's Avatar
abdr500
thanks to all where can i buy i the bits for this if i wanted to do a rebuild on it
Old Oct 29, 2007 | 08:41 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
take it to pip! had mine mapped there he knows everythin there is to know about rx's! will cost you tho!
Old Oct 29, 2007 | 10:45 PM
Mr Whippy's Avatar
Mr Whippy
Oderint dum metuant
If you want to do it yourself then the bits are available from Hurley Rotary Engineering in Coventry. There are also videos showing step by step rebuild info floating around too.
Old Oct 31, 2007 | 09:46 PM
rstdaz's Avatar
rstdaz
Sounds like you've lost a seal or similar on one of the rotors, probably the rear. Compression test it, but hold the button in while someone starts it, you should get 3 even bounces - i bet you don't.
unfortunately yes it sounds like rebuild time, but compression test it first - it could be a flooded rotor or fouled spark plug or something silly but youll be very lucky if it is!
compression test it/get it done!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
