HOW TO SET THROTTLE POS SENSOR
IIRC if it is the cossie one, the original 'book' way of setting up was to undo the two bolts so that the TPS could move freely. then rotate against the direction of the spring about 90 degrees (will only turn one way that far) and then let go. In theory that should be the correct position.
Otherwise, you need to use a voltmeter to makesure that you have the correct output voltage. I will need to dig out the ecu pins though
JJ
JJ
Only comment I would make is that when I had trouble with mine, the TPS was miles out, which led the ECU to disengaging the ISCV, which leads to a very very high idle.
If it went for a setup, are you sure they havent just got the mixture wrong (ie the CO screw on the front of the ECU)? Will tend to hunt if either too lean or rich at idle. Just a thought
Remember though - I am just a DIY monkey
JJ
JJ
hmm, maybe could be mixture screw, shud get it checked.
Wen cold it will rev up to 1300rpm, hold it for 3 or 4 seconds, but then will drop, and it will have to pick its self up again to 1300rpm.
Wen Hot it idles ok, just a tiny fluctuation?
