WTF Is wrong with my Pulsar! (It is the HG :cry: pg5)
#82
Gutted for you matey!!
But does sound block ish to me.. I cant think of anything else to say,that hasnt already..Burn it and buy me 5!!!!!!!!
Pete...
Pete...
#89
Radders loving the new sig
Fucking Japanese piece of shit
Worse than a Ford?
3 Recoverys,
New water pump,
New radiator,
New exhaust gasket
New rear brake pads
Door won't fucking open
4 threads on PF
Over heats like a twat
and burns oil like no tomorrow
ALL IN TWO SODDING WEEKS
Worse than a Ford?
3 Recoverys,
New water pump,
New radiator,
New exhaust gasket
New rear brake pads
4 threads on PF
#93
Originally Posted by jungleistmassiv
any more suggestions as to what could be wrong with it yet rad?
Don't mean to be funny, but that ruddy great numberplate on the front of it isn't blocking airflow to the rad is it???![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
#100
Slap Head
M8 Seriously go onto
http://www.gtiroc.com/forum
They will be able to help you out....They are fucking ace cars when they are running right I love mine to bits so seriously keep with it!!!!!
#103
what about the turbo oil return? Check thats clear.... If its not, the oil could pool in the bearing housing, cook it, force it past the seals etc
.... Might be worth checking the turbo feed hose as well for the same reasons
#107
are you sure there isn't jsut a bad earth and is shorting out the oil temp and water temp?????
does it sit at a normal temp, then just flick to full (hot) ???
or does it climb gradually?
#111
if it was my car, i'd be asking why OIL would get that hot that fast????
water is heated up by engine (i.e. HG), and heats up quite quick, but oil??
what can cause oil to heat up so fast???
even on track i cant get me oil to heat up that fast
#112
Slap Head
mick_rst
Can you help me out mate, I'll PM you![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Let me know exactly what its doing and I'll look into it for you!!!
did you do the compression test hot or cold - try both and look for a difference...
It'll be sorted soon m8 the you'll realise how good they can be LOL!!!!
#113
Alot of Gtir temp gauges sit at 1/2 and never move, so they may not be that accurate.
#115
Got a guide here http://www.gtirworkshopmanual.com/default.aspx?v=403 so will do that tomorrow and have everything crossed and touch as much wood as possible
![](https://passionford.com/forum/images/smilies/ghey.gif)
All the earths seem fine too, had a look around and cant see any that are loose or anything
Originally Posted by mick_rst
mick_rst
compression test was done cold btw
#117
#118
#119
Originally Posted by RWD_cossie_wil
I'm afraid to say this sounds just like my old saff that had a cracked block...
. Personally I would rip the head off and see what the score is, save any more fucking around
..... Get it pressure checked and inspect the block as best you can while its still in the car
ended up me cracking two out of 4 cylinder bores
take the head off and look very carefully
defo sounds very similar probs to what i had
hope you get it sorted mate ,usually its drive train related probs with the pulsars lol
good luck
#120
yeah going by the above about the oil/water cooler. kinda explain things
once you find the fault, please keep it, you will enjoy it i'm sure (though not speaking from experience)
