PC HELP NEEDED URGENT..............
Chasing Radders
EVERYTIME i open a window...be it passionford or ebay or anything i get a box with Windows Intaller pop up. It then takes about 2 minutes before the page will show up.
Whats up with it and how do i fix the bloody thing
Tiff, Its more than likely that if you are running a pop up blocker and its getting past this than you have an adware problem, you need to make sure you have spyware installed, but you must make sure it is updated and you must run it because they dont automatically pick adware up. If your on BT use BT antispy
As I said you must run it dont rely that you have it that you have got protection
hope that helps
Si
hope that helps
Si
Super Moderator
tiff .. goto
http://www.spywareinfo.com/~merijn/programs.php
download it and run it ..
post up the results..
also run adaware and spybot ...
MP for K.I.S.S
Sounds like your Windows Installer database has corrupted and it thinks there is a program that is linked to IE that needs installing again, hence the reason it pops up all the time.
It should, on the message, tell you what the program is its trying to reinstall. once you know this, go to www.microsoft.com and download this
http://download.microsoft.com/downlo...bd/msicuu2.exe
Its the Windows Installer Cleanup Utility. Load it up and look for an entry in the list for the program that is causing you the problem. Find it, highlight it and run the cleanup against it.
Should be OK. If not, post the name of the program and I'll do some more digging.
Matt
Matt
JoeyBoyden
04-01-2024 02:36 PM
jessie_rs
11
03-06-2019 04:57 PM
rog
04-09-2015 12:10 PM
borboyous
22-08-2015 11:17 AM
