40MM DROP HELP
40MM DROP HELP
DOES ANYONE KNOW IF IT WOULD BE POSSIBLE TO FIT A SUSPENSION KIT WRONGLY. I'VE HAD A 40MM KIT PUT ON MY 1989 ESCORT RS TURBO BUT THE FRONT END SEEMS TO HAVE DROPPED CONSIDERABLEY MORE THAN 40MM, MORE LIKE 80MM!! THE PART NUMBERS APPEAR TO BE CORRECT.
CHEERS!
CHEERS!
Originally Posted by benreader
thanks thats really helpful! ok so now i've turned caps lock off can someone give me a sensible bit of advise. thanks!
benreader did you do the springs your self?
what suspension kit is it?
as i made a mistake on the gmax kits on my old cabby as it said to remove the bump stops on the shocks
omg what a disaster that was
but the front will always sit lower than the back
no i paid a garge to fit them for me, i cant see there being a possible way to actually do it wrong, they are the right way up etc... the rear is lowered by the correct amount but the front is double what it should have been, its not just that it looks lower it is lower. my mate also has an rs on a 40mm drop with standard wheels and the difference is huge!
if you remove the bump stops then its takes the height of the bump stop off aswell so around 40mm
plus the shocks will crash and bang as there is no bump stop so the shock will always be bottoming out
you need the bump stops on , no need to cut them or anything, just get some bumpstops and job done
am i right in thinking the only thing that determines the ride height is the spring itself? the spring is labelled as a 40mm, im sure it must have been made/cut incorrectly at the manufacture stage?
removing the bump stops will not affect ride height. All they will do is stop the shock bottom out when the spring is fully compressed, when hitting a pot hole / harsh cornering etc.
Are you sure you have the right springs for your car? They are weighted differently depending how much the engine weighs.
Rich
Rich
jungleistmassiv
it will be the bump stops mate
when i did my cabby the front end was very very low, took it down the road and it bottomed out everywhere even on the slightest bump
this was a 40mm drop aswell, now im sure the shock only has 60mm travel on them so removing the bump stop is ging to cause problems
when i fitted my bump stops back on the car drove better and the ride was nice, but becuase the car had been bottoming out the springs had already compressed where they wanted to go so the car was still low but the bump stops raised it up slightly
enough that i was happy with
its not far off the bump stops
as i said once you bottom the shock out a couple of times the springs wont be doing there job so will compress and settle in too far this is what happened to mine
you need the bump stops regardless
but also th eback end will always be higher on a hatchback anyway due to no weight on the back
most of my old escorts have been the same and usually had to take a coil off the rear springs, until i went for 60 at the back and 40 at the front and it settled nicely
the reason i went 40 all round on my caby was it was sumer and the weight of the roof doen settle the car lovely
ok mate there is a ford scrapper round the corner from me so i'll go and get some. before i start taking it all apart will you just expand on exactly how the bumpstops raise it up a bit, i thought the spring was what determined the ride height? thanks!
does it crash and bang when you hit a pot hole?
if so then the shocks bottoming out so will need these anyhow
the front will be very low anyway as thats just the gmax kit
but because the bump stops have been removed the springs has settled in further than it should of
so you not going to get the height back, may get a little but the ride should be better
it was on mine
also why its aart ake srure the srings are not upside down aswell, i dont think you can but just double check
this was the gmax kit on mine with a 40mm drop
as you can see the front is lower than the back, this is how all gmax kits are
it was on mine
yeah thats it! thats exactly what mine look like now. so if i get some bumpstops sorted out and some 20mm springs maybe, do you think this would level things out and sort out the ride?
Andypandy260
23-09-2015 10:28 PM
